    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.6k Views 69 Watching
      Rodin! πŸ˜„
      • jolranJ
        jolran
        No worries πŸ˜„ Nice chest.
        • panixiaP
          panixia
          it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
          i suppose i installed it properly and also updated ttlib to last version..
          i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
          • jolranJ
            jolran
            Same here. I only had it working in 2014.
            Error "defined method `force_encoding' for #String:0xb10993c"
            This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
            • panixiaP
              panixia
              yeah. force encoding blablabla.. getting similar message when loading sketchup
              but.. it says su8 is supported..
              • D
                d12dozr
                Thanks, Thomthom. Time to play!
                http://goo.gl/f7ooYh
                • jolranJ
                  jolran
                  Ah, yeah you are right. Then I guess he just probably forgot to set up some conditions for Su8. Well see when he get's back.
                  Meanwhile do a testspin in 2014. πŸ˜„
                  It may have be a condition set on line 26 in the loader rb
                  "file = FILE.dup.force_encoding("UTF-8")"
                  If I remember correctly Ruby 1.8 (Su8) does not have that method..
                  I'm not gonna mess with that since I don't know how he has things set up with TT_Lib so I suggest waiting for his return..
                  • panixiaP
                    panixia
                    never thought for a second to fix the code by myself πŸ˜†
                    anyway i downloaded su15 and it works perfectly.. too bad su2015 doesn't fit my needs at the moment (mainly for the other 31454535 plugin i use)
                    this tool is great! sort of pseudo-nurb brother of vertex tools..
                    waiting for su8 news.. πŸŽ‰
                    • U
                      unclex
                      Yes
                      For 2013 or 8 user
                      just change that like this
                      "file = FILE"
                      • BoxB
                        Did you restart Sketchup after installing it?
                        • jolranJ
                          jolran
                          Yes
                          For 2013 or 8 user
                          "file = FILE"
                          Like I said, better let Thomthom do it properly. Even if it looks like a simple fix, it "may" have consequences for TT_lib since removing encoding.
                          Although, nothing "bad" should happend if you only experiment at 1 place..
                          • U
                            unclex
                            It's just always updating...
                            Cannot Click or DoubleClick
                            and when SU opening, nothing prompt
                            • thomthomT
                              @jolran said:
                              Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                              Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                              It's simple bezier quad patches with 4x4 control points each. The bezier calculation is based on the bezier example script posted by @last many years ago, I just ported it to C for faster calculations. You can see the source in TT_Lib2.
                              • thomthomT
                                @jolran said:
                                How do you add Tripatch to Qaudpatch ? Possible ?
                                No, this was on my todo, once the quad patches was done. I removed the main toolbar button for it right before release, but forgot there was menu items and that second webdialog toolbar. I should push a new update the removes the unused controls in the dialog.
                                • thomthomT
                                  @box said:
                                  This rough test torso is less than five minutes work.
                                  Really? 😲 I didn't expect the extension to be that useful in it's current state. I hope people do post back more picture.
                                  • OxerO
                                    Oxer
                                    Thanks you very much for the plugin!! πŸ‘ πŸ‘
                                    I installed it in SU2014 & SU2015 on Mac but the plugin didn't work, I found a conflict with smartdrop.rb and Sketchyphysics, I deleted smartdrop.rb (I use tt.raytracer now to drop components) and I have deactivated Sketchyphysics on SU2014 with Sketchucation Plugins Manager and Bezier Surface work fine now.
                                    http://www.oxervision.blogspot.com/
                                    • thomthomT
                                      Should work with SU7 and up, I think. Any error messages?
                                      • thomthomT
                                        Yea, with my new subdivison extension I'm certainly dropping support for anything older than SU2014.
                                        Though this was written before SU2014 and it should work. (Though might have introduced a bug when I added SU2014 support. Can you provide the full error message and exact SketchUp version and OS?)
                                        • thomthomT
                                          The bla bla bla bit of error message is in fact very useful for developers when debugging errors - please post all of it when reporting issues.
                                          • thomthomT
                                            Ah - right, I'll fix that and push an update next week.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
