    SketchUp 8 slower than version 7
    13 Posts 8 Posters 2.1k Views 8 Watching
    • A
      arjunmax09
      Hi everyone...I'm using Sketchup 8 pro and find it bit slow than version 7. Is anyone having the same experience as mine..??..Is there any solution to speed up this 8 version?
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • Chris FullmerC
        You might try unloading all your plugins for a while. I have seen quite a few other reports, and so far all of them have been tied to sdome plugins that are drastically slowing down 8.
        Hopefully that will fix it. If it does, you will probably want to figure out which plugin is doing the damage.
        Hopefully that will help. Let us know how it goes,
        Chris
        All my Plugins I've written
        • thomthomT
          Or could it be that your fresh installed SU8 hasn't got hardware acceleration activated? I find SU to not always pick the correct OpenGL mode...
          • A
            arjunmax09
            @chris fullmer said:
            I have seen quite a few other reports, and so far all of them have been tied to some plugins that are drastically slowing down 8.Hopefully that will fix it.
            Chris
            can you tell me which plugins have been known so far in slowing down sketchup?
            • thomthomT
              I just had a issue where SU8 would be very slow. After uninstalling SU8 and installing again everything works fine and snappy.
              • jbacusJ
                jbacus
                Hi guys,
                In our labs, SU8 renders significantly faster than SU7 and about the same as SU7.1. YMMV, depending what you're paying attention to in performance terms. Perceived performance turns out to be surprisingly subjective and often has as much to do with the last model you opened in SketchUp (and your performance experience with it at that time) as it does with the actual raw performance of the system.
                Also, SketchUp performance appears inversely proportional to the amount of time left before an important deadline 😉
                john
                "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                John Bacus
                jbacus@sketchup.com
                • thomthomT
                  • M
                    marne
                    🤣 true, true
                    • G
                      glro
                      @jbacus said:
                      Hi guys,
                      john
                      a joke might not be sufficient to explain the situation i am experiencing
                      on my computer, SU15 64 bits is even slower than all previous versions
                      and no plugin can be accused, since there are hardly any in the SU15 plugin folder
                      • FrederikF
                        Frederik
                        I'm definitely experiencing the contrary...
                        I.e. Opening or saving a big file is super fast with SU2015 64-bit...
                        Where/when are you experiencing a slow down??
                        Cheers
                        Kim Frederik
                        • K
                          kaas
                          @glro said:
                          ...on my computer...
                          maybe if you could share some specs about your computer and the kind of sketchup file (statistics) people could help
                          • G
                            glro
                            OK
                            I agree, it depends upon what you are paying attention to
                            plugins using ruby lines of code moving components, or screening of special types of components among all objects in the model, seem to be much slower on sketchup 15 compared to sketchup 8
                            but i noticed that all that is related to showing the model on screen is much faster on sketchup 15 compared to sketchup 8
                            so i guess some choices have been made to allow more memory to this and less to that
                            @jbacus said:
                            Hi guys,
                            john
                            • thomthomT
                              Do you have code examples with timing to demonstrate this?
