    Making a dome with a dome with a non-circular base
    6 Posts 5 Posters 538 Views 5 Watching
    • leedeeteeL
      leedeetee
      Is it possible to create a dome-like structure, but whose base is non circular, like the picture attached?
        Using TIG's EEbyR to make a portion....
        Lee Dome.skp
        • leedeeteeL
          leedeetee
          Of course, thanks Rich. Much obliged, you're a scholar and a gent. 😄
          • T
            tfdesign
            I've just spent ages trying to find that plugin, only to realise that it's called "Extrude Edges by Rails", and not just 'EEbyR'-Doh!
            I really dislike abbreviations! 😳
            here; ➡ http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            My book "Let's SketchUp!" Download from here
            • charly2008C
              charly2008
              Not to forget Curviloft.
              Charly
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                The "Follow me" Tool can be used to make a profile follow such a path.
                Just make sure that you do not generate facets that are too small to fill. If this is the case, draw larger and scale down when done.
                Just ideas.
