    Material ID and alpha channel
    renderpluginsextensions
    3 Posts 2 Posters 5.9k Views 2 Watching
      JohanR
      Hi, here´s another noob question. I´ve found myself in need of help from the alpha channels rendered from vray when i´m in photoshop. I know how to change the channel number, so that a meterial get in the same channel as the background alpha (hope i´m not confusing you now).
      The thing i wanna do is to change the channel colors and have them as seperate channels; red, green and blue, so that i can select these masks in PS later. What i have now, is just the black/white one.
        Assuming you're using the latest VfSU 1.48.xx you set your colour at the ID Color under Options for that material.
          JohanR
          Thanks dude!
