    Adding objects into a group/component
    13 Posts 10 Posters 22.5k Views 10 Watching
    • C
      croviax
      How do i add objects into an existing group without exploding the group and grouping back again?
      • TIGT
        Try
        group.entities.add_instance(other_group.entities.parent, other_group.transformation*group.transformation) other_group.entities.parent.instances[1].material=other_group.material other_group.entities.parent.instances[1].layer=other_group.layer### you can also copy over other attributes of 'other_group' if appropriate
        other_group.erase!
        'other_group' is 'cloned' into 'group.entities' and the original erased - here we also copy its material and layer...
        • C
          croviax
          I'm sorry, but how do i use that script?
          • TIGT
            It's not a script it's a snippet of code... ๐Ÿ˜•
            Sorry I thought you wanted a Ruby way of doing it... ๐Ÿ˜’
            To do it by hand do this.
            Select the Object[s] you want to relocate into the Group.
            Use
            Menu > Edit > Cut
            The selection is put it onto the clipboard.
            Double-click the Group so you are editing its entities.
            Use
            Menu > Edit > Paste-in-Place
            The Selected Object[s] now 'moves' into the Group.
            To duplicate it into the Group use
            Menu > Edit > Copy
            To place it into the Group at the same location use the
            BUT to choose where to put it use
            Menu > Edit > Paste
            You then pick its new location inside the Group.
            To 'move' something out of a Group reverse the process...
            Edit the Group.
            Select the Objects to 'move' out.
            Menu > Edit > Cut
            The exit the edit and then
            To put into the Model... or edit another Group and paste the objects into that etc...
            To 'copy' things rather than 'move' their context use Edit > Copy rather than Edit > Cut
            You can do something similar with a Component Instance Edit - to add/move objects etc.
            • C
              croviax
              Hahah, didn't know the 'Paste in Place' command exist..
              Thanks a lot ๐Ÿ˜„
              • T
                Taylor64
                Thanks a lot ๐Ÿ˜„
                This may be a helpful hint, you can customize your shortcuts on your keyboard, by going to window/preferences then pick short cuts from the menu and set your "paste in place" command to e.g.: "Ctrl-shift-v". I don't know why this isn't in the default settings???
                Also use the common shortcuts such as Ctrl-C for copy and Ctrl-v for paste. I can't remember if sketchup does the Ctrl-d for duplicate.
                make any sense?
                • pyrolunaP
                  pyroluna
                  You can also drag a group into another group in the outliner window.
                  Something similar is explained in this video: http://www.youtube.com/watch?v=7OBljxmDLSI
                  • B
                    BrooksL
                    Thanks TIG and Pyroluna! ...I don't know why these aren't mentioned on the SketchUp doc pages about groups & components; you'd think it would be an obvious followup concern...
                    • M
                      mwm5053
                      WOW Tig, genius, you are the the man, so obvious but never thought of that
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                      • G
                        ghanson
                        This thread is still saving the minds of new SketchUp users!
                        Thanks for the clear explanation and direction.
                        • S
                          sattar
                          Hi , how to add an item to an existing component instances. I mean I have 4 copies of an item in my model , 3 are instances of a component but the forth , for some reason , is not. How do I make it part of the component instances.
                          • T
                            thiaguinho
                            I can attest to the copy and paste in place. Works wonders. However, if there is a lot of geometry that needs to be added, I'd recommend using the outliner and dragging them in there!
                            • mariochaM
                              mariocha
                              @tig said:
                              Try
                              other_group.erase!
                              Thanks for this. Was useful.
                              Of course, assigning names (variables) to each instance, makes copying layer straightforward;
                              group2.layer = group1.layer
                              %(#008000)[Mario C.
