    [Plugin] Explode Group to Layers
    4 Posts 3 Posters 6.3k Views 3 Watching
      (c) TIG 2010
      Explodes a Group, BUT unlike built-in .explode method, which puts Exploded Entities that are on 'Layer0' onto the Layer of the original Group, this keeps all of the Exploded Entities' Layers unchanged.
      Usage: explodegroup2layers()
      If no argument is given then the current Selection is used and any Groups in it are processed.
      If an argument is given and it's a Group then that is processed.
      e.g. explodegroup2layers(group)
      If an argument is given and it's an Array then any Groups in that Array are processed.
      e.g. explodegroup2layers([group1,group2,group3])
      Probably most useful inside other tools to keep exploded entities on the expected layers.Put into Plugins folder [or copy code into another tool]...PayPalButton
        This is run via the Ruby Console? Any chance of a little pictorial? I have tried it throught the Console but the second option has my head in a vice
          Normally you'll just select some groups and type explodegroups2layers in the Console.
          When it's called within another tool you can set it to run on a selection explodegroups2layers() or on one group explodegroups2layers(group) or on an array of groups explodegroups2layers([gp1,gp2,gp3]).
          Most users will use it the first way.
          the optional 'arguments' make it more flexible for use within other tools... 🤓
          • bagateloB Offline
            bagatelo
            I'm looking for a plugin that creates a new layer for each object in the scene or in the selection, either component or group, without considering subgroups. Has anyone done something like this?
