    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 35.5k Views 17 Watching
    • TIGT
      (c) TIG 2010
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided that the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      You need this file
      #SilhouetteToPlane.rb >>> Plugins Folder
      You must also have this file
      #WorkPlane.rb >>> Plugins Folder
      Usage:
      Make or choose a 'WorkPlane' that is located on the 'plane' onto which
      you want to project your 'flattened' Geometry.
      Select the 'WorkPlane' and the required Geometry [Edges etc, note that
      Faces etc will be ignored], and/or Groups, and/or Component_Instances.
      Run this Tool from the menu 'Plugins' > 'Silhouette to Plane'
      or type 'silhouettetoplane' in the Ruby Console.
      If there is no 'WorkPlane' and/or other objects in the Selection you get an
      error message.
      Assuming it runs...
      All Edges in the Selection that are not 'hidden' or not on 'off layers' are
      projected onto that 'plane'.
      The new 'flattened' Edges are put into a new Group named 'SIL_123456.789'
      [it has a 'date/time' suffix].
      Each new Edge takes the original Edge's layer.
      The new Edges are inspected and only those that are needed to form a fully
      faced 'silhouette' WITHOUT cut-outs are retained.
      With this version internal 'hole' cut-outs in silhouettes are NOT formed.
      On completion the new Group ['SIL_123456.789'] is left highlighted.
      Donations:
      by PayPal to info @ revitrev.org PayPalButton ___________________________________________________________________________
      Version:
      1.0 20101022 First release.
      1.1 20101023 The correct Plane of a 'WorkPlane' is now used even if it has
      been Transformed inside its own Group.
      Speed and reliability improved. Title fixed.
      ___________________________________________________________________________#SilhouetteToPlane.rb
      • shuraS
        shura
        very good idea TIG! Although, I am getting some errors here - with a single loop of edges it works fine, but for several faces it gets messed up:
        btw, would it be possible to have the projection lines run all to the same focal point, similar to Radial Lines plugin? Like this we could also have a flattened picture of a perspective view.
        • TIGT
          This is the first [buggy] release!
          Can you post and example SKP so that I can see the errors...
          • shuraS
            shura
            SU 7.1 on Vista, have tons of plugins but only one error so far (wxfsu) ...
            silhouetteError.skp
            • honoluludesktopH
              honoluludesktop
              TIG, How many plugin, and point releases are you currently averaging? 1 a week?-)
              And, you still find time to help us. Thanks!!!!!
                1 a week?
                1 a day is more appropriated πŸ˜‰
                • Didier BurD
                  Didier Bur
                  Hi TIG,
                  I suggest you change line #63 to: @model.start_operation("Silhouette to Plane") 😎
                  Thanks for all your hard work !
                  DB
                  • TIGT
                    Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=281445#p281445
                    The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
                    Title fixed.
                    • EarthMoverE
                      EarthMover
                      Great Script! πŸ‘ Perfect for sorting out faces that have trouble closing. Could you possibly have it so that if no work plane is selected, that it will default to a placing the silhouette on the 0 z plane? Similar to ThomThoms Flatten script in his "Plan Tools", except yours automagically creates the face and groups it.
                      Content Creator at Skapeup
                      • TIGT
                        You could always make a quick WorkPlane on the ground...
                        • shuraS
                          shura
                          Just great! You are a hero, hats off to thee!
                          • TIGT
                              This sort of image must be at each first post πŸ˜„
                              • EarthMoverE
                                EarthMover
                                Here's another example.
                                Silhouette to plane is also great for flattening a set of looped edges you want to be planar to form a face, but cant seem to find the vert that's out of whack.
                                • X
                                  xrok1
                                  this could be great for making face me components! render the 3d version then apply as texture to the 2d. πŸ˜„
                                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                  • B
                                    Ben Ritter
                                    TIG, fabulous! Thank you for the flatten to plane script as well. You are very generous, and gifted.
                                    • C
                                      caleidos4d
                                      TIG!!!
                                      http://www.caleidos4d.it
                                      • D
                                        danbig
                                        Thanks, TIG. Amazing script.
                                        Does this plugin do the flatten to plane, or is that a separate plugin? I can't seem to find the command for flatten to plane. (Silhouette to Plane is working great)
                                        • shuraS
                                          shura
                                          Flatten to Plane:
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=31895
                                          • shuraS
                                            shura
                                            Just to point out again what Adam already said, Silhouette to Workplane makes closing difficult outlines sooo easy. Brought back the faith in freehand tool to me.
                                            with freehand tool quickly drawn outlines often do not close. solved with silhouettes to workplane.
                                            Rocky, that is a pretty smart idea. I am having thoughts about this kind of matte painting tricks all the time.
                                            (like here: http://forums.sketchucation.com/viewtopic.php?f=79&t=31069)
                                            thanks again for your generosity TIG!
                                            • 1 / 2
