    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 34.1k Views 17 Watching
      @earthmover said:
      Great Script! ๐Ÿ‘ Perfect for sorting out faces that have trouble closing. Could you possibly have it so that if no work plane is selected, that it will default to a placing the silhouette on the 0 z plane? Similar to ThomThoms Flatten script in his "Plan Tools", except yours automagically creates the face and groups it.
      You could always make a quick WorkPlane on the ground...
      • shuraS Offline
        shura
        Just great! You are a hero, hats off to thee!
            This sort of image must be at each first post ๐Ÿ˜„
            • EarthMoverE Offline
              EarthMover
              Here's another example.
              Silhouette to plane is also great for flattening a set of looped edges you want to be planar to form a face, but cant seem to find the vert that's out of whack.
              Content Creator at Skapeup
              • X Offline
                xrok1
                this could be great for making face me components! render the 3d version then apply as texture to the 2d. ๐Ÿ˜„
                โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                  Ben Ritter
                  TIG, fabulous! Thank you for the flatten to plane script as well. You are very generous, and gifted.
                    caleidos4d
                    TIG!!!
                    http://www.caleidos4d.it
                      danbig
                      Thanks, TIG. Amazing script.
                      Does this plugin do the flatten to plane, or is that a separate plugin? I can't seem to find the command for flatten to plane. (Silhouette to Plane is working great)
                      • shuraS Offline
                        shura
                        Flatten to Plane:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=31895
                        • shuraS Offline
                          shura
                          Just to point out again what Adam already said, Silhouette to Workplane makes closing difficult outlines sooo easy. Brought back the faith in freehand tool to me.
                          with freehand tool quickly drawn outlines often do not close. solved with silhouettes to workplane.
                          Rocky, that is a pretty smart idea. I am having thoughts about this kind of matte painting tricks all the time.
                          (like here: http://forums.sketchucation.com/viewtopic.php?f=79&t=31069)
                          thanks again for your generosity TIG!
                          • JClementsJ Offline
                            JClements
                            TIG:
                            When I click on the script's download button the #SilhoutteTpoPlane.rb downloads. I put the script in the plugins directory of SU8. When I open SU8 I get the following error:
                            %(#FF0000)[Error Loading File #SilhouetteToPlane.rb
                            no such file to load -- #WorkPlane.rb
                            Should #WorkPlane.rb also have been downloaded?
                            Regards, John
                              @jclements said:
                              TIG:
                              Regards, John
                              John
                              IF you had read the notes you'd see that you need 'WorkPlane.rb'... because you must first make and then select a 'WorkPlane' with your other parts you want to project - that's how it knows what plane to project its result on to... ๐Ÿ˜’
                              • CAntonisC Offline
                                CAntonis
                                Working great as always
                                Thank U TIG
                                  Bertier
                                  sweet
                                  • H Offline
                                    Heven7_floor
                                    Thanks ๐Ÿ˜ , it is great script for mechanic model favour, this plug-in shall mostly advance to project 3d model in STD plan,
                                    but I found some error happen, when I test by simple cylinder ,which was rotated a bit from origin , there are 1 error time of total 4 time
                                    I love this script , and hope it could been tune-up ,but I am begin to learn for SU plugin codding , shame to less helping ๐Ÿ˜ณ
                                    rotate cylinder model testing
                                      JClements
                                      TIG, not sure if this is how you intended the script to work or not.
                                      Using SU8. If I select a bunch of standalone geometry and a couple of groups, only the standalone geometry gets project to the working plane. Each group has to be selected individually to be projected.
                                        Everything should project I'll check into it...
                                        Do you get the same 'error' with components too ?
                                          JClements
                                          Hi TIG:
                                          Yes, the script works with SU8 and with components. However, the selection set seems to require that it include all of one type of geometry only, either: all loose geometry or all groups or all components.
                                          Attached is the test .skp I used.
                                          John
                                          Silhouette test (SU8, 07 Dec 2010).skp
                                          • N Offline
                                            nektares
                                            this could be extremely useful!! i will try it out later today! thanks Tig!
