    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 35.5k Views 17 Watching
    • honoluludesktopH
      honoluludesktop
      TIG, How many plugin, and point releases are you currently averaging? 1 a week?-)
      And, you still find time to help us. Thanks!!!!!
        1 a week?
        1 a day is more appropriated πŸ˜‰
        • Didier BurD
          Didier Bur
          Hi TIG,
          I suggest you change line #63 to: @model.start_operation("Silhouette to Plane") 😎
          Thanks for all your hard work !
          DB
            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=281445#p281445
            The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
            Speed and reliability improved.
            Title fixed.
            • EarthMoverE
              EarthMover
              Great Script! πŸ‘ Perfect for sorting out faces that have trouble closing. Could you possibly have it so that if no work plane is selected, that it will default to a placing the silhouette on the 0 z plane? Similar to ThomThoms Flatten script in his "Plan Tools", except yours automagically creates the face and groups it.
              Content Creator at Skapeup
                You could always make a quick WorkPlane on the ground...
                • shuraS
                  shura
                  Just great! You are a hero, hats off to thee!
                      This sort of image must be at each first post πŸ˜„
                      • EarthMoverE
                        EarthMover
                        Here's another example.
                        Silhouette to plane is also great for flattening a set of looped edges you want to be planar to form a face, but cant seem to find the vert that's out of whack.
                        • X
                          xrok1
                          this could be great for making face me components! render the 3d version then apply as texture to the 2d. πŸ˜„
                          • B
                            Ben Ritter
                            TIG, fabulous! Thank you for the flatten to plane script as well. You are very generous, and gifted.
                            • C
                              caleidos4d
                              TIG!!!
                              http://www.caleidos4d.it
                                danbig
                                Thanks, TIG. Amazing script.
                                Does this plugin do the flatten to plane, or is that a separate plugin? I can't seem to find the command for flatten to plane. (Silhouette to Plane is working great)
                                • shuraS
                                  shura
                                  Flatten to Plane:
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  • shuraS
                                    shura
                                    Just to point out again what Adam already said, Silhouette to Workplane makes closing difficult outlines sooo easy. Brought back the faith in freehand tool to me.
                                    with freehand tool quickly drawn outlines often do not close. solved with silhouettes to workplane.
                                    Rocky, that is a pretty smart idea. I am having thoughts about this kind of matte painting tricks all the time.
                                    (like here: http://forums.sketchucation.com/viewtopic.php?f=79&t=31069)
                                    thanks again for your generosity TIG!
                                    • JClementsJ
                                      JClements
                                      TIG:
                                      When I click on the script's download button the #SilhoutteTpoPlane.rb downloads. I put the script in the plugins directory of SU8. When I open SU8 I get the following error:
                                      %(#FF0000)[Error Loading File #SilhouetteToPlane.rb
                                      no such file to load -- #WorkPlane.rb
                                      Should #WorkPlane.rb also have been downloaded?
                                      Regards, John
                                        @jclements said:
                                        TIG:
                                        Regards, John
                                        John
                                        IF you had read the notes you'd see that you need 'WorkPlane.rb'... because you must first make and then select a 'WorkPlane' with your other parts you want to project - that's how it knows what plane to project its result on to... πŸ˜’
                                        • CAntonisC
                                          CAntonis
                                          Working great as always
                                          Thank U TIG
                                          • B
                                            Bertier
                                            sweet
