    [Plugin] Silhouette to Plane v1.1
    32 Posts 17 Posters 34.3k Views 17 Watching
      This is the first [buggy] release!
      Can you post and example SKP so that I can see the errors...
      • shuraS Offline
        shura
        SU 7.1 on Vista, have tons of plugins but only one error so far (wxfsu) ...
        silhouetteError.skp
        • honoluludesktopH Offline
          honoluludesktop
          TIG, How many plugin, and point releases are you currently averaging? 1 a week?-)
          And, you still find time to help us. Thanks!!!!!
            1 a week?
            1 a day is more appropriated πŸ˜‰
            • Didier BurD Offline
              Didier Bur
              Hi TIG,
              I suggest you change line #63 to: @model.start_operation("Silhouette to Plane") 😎
              Thanks for all your hard work !
              DB
                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=281445#p281445
                The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group.
                Speed and reliability improved.
                Title fixed.
                • EarthMoverE Offline
                  EarthMover
                  Great Script! πŸ‘ Perfect for sorting out faces that have trouble closing. Could you possibly have it so that if no work plane is selected, that it will default to a placing the silhouette on the 0 z plane? Similar to ThomThoms Flatten script in his "Plan Tools", except yours automagically creates the face and groups it.
                  Content Creator at Skapeup
                    You could always make a quick WorkPlane on the ground...
                    • shuraS Offline
                      shura
                      Just great! You are a hero, hats off to thee!
                          This sort of image must be at each first post πŸ˜„
                            EarthMover
                            Here's another example.
                            Silhouette to plane is also great for flattening a set of looped edges you want to be planar to form a face, but cant seem to find the vert that's out of whack.
                            • X Offline
                              xrok1
                              this could be great for making face me components! render the 3d version then apply as texture to the 2d. πŸ˜„
                                Ben Ritter
                                TIG, fabulous! Thank you for the flatten to plane script as well. You are very generous, and gifted.
                                  caleidos4d
                                  TIG!!!
                                  http://www.caleidos4d.it
                                    danbig
                                    Thanks, TIG. Amazing script.
                                    Does this plugin do the flatten to plane, or is that a separate plugin? I can't seem to find the command for flatten to plane. (Silhouette to Plane is working great)
                                    • shuraS Offline
                                      shura
                                      Flatten to Plane:
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=31895
                                      • shuraS Offline
                                        shura
                                        Just to point out again what Adam already said, Silhouette to Workplane makes closing difficult outlines sooo easy. Brought back the faith in freehand tool to me.
                                        with freehand tool quickly drawn outlines often do not close. solved with silhouettes to workplane.
                                        Rocky, that is a pretty smart idea. I am having thoughts about this kind of matte painting tricks all the time.
                                        (like here: http://forums.sketchucation.com/viewtopic.php?f=79&t=31069)
                                        thanks again for your generosity TIG!
                                        • JClementsJ Offline
                                          JClements
                                          TIG:
                                          When I click on the script's download button the #SilhoutteTpoPlane.rb downloads. I put the script in the plugins directory of SU8. When I open SU8 I get the following error:
                                          %(#FF0000)[Error Loading File #SilhouetteToPlane.rb
                                          no such file to load -- #WorkPlane.rb
                                          Should #WorkPlane.rb also have been downloaded?
                                          Regards, John
                                            @jclements said:
                                            TIG:
                                            Regards, John
                                            John
                                            IF you had read the notes you'd see that you need 'WorkPlane.rb'... because you must first make and then select a 'WorkPlane' with your other parts you want to project - that's how it knows what plane to project its result on to... πŸ˜’
