    Close webdialogs on File-New/Open
    14 Posts 4 Posters 1.1k Views 4 Watching
    • P Offline
      Pout
      Is there a way to observe if the user opens a new or existing file so the open webdialogs can be closed?
        You shouldn't need an observer if the tool-class calling the dialog [ @dlg] has a deactivate() method which includes @dlg.close if @dlg and @dlg_is_open or equivalent. Exiting the tool then closes the dialog if it has been set up initially and is still 'open'. The instance variable @dlg_is_open can be set true/ false as you open and then close the dialog @dlg.
        If you have closed the dialog in the Tool then later call self.deactivate() etc...
        You should also use it in the onCancel() method too...
        Alternatively the code
        begin @dlg.close rescue end
        does it trapping errors for you in the deactivate() ???
        Of course on a PC opening your dialog so it is 'modal' with '@dlg.show_modal{#what_to_do#}' prevents you even exiting the Tool or the SKP until the dialog is closed itself.
          That's assuming the webdialog is opened by a tool. If it isn't, then it's the AppObserver one has to use: http://code.google.com/apis/sketchup/docs/ourdoc/appobserver.html
          • P Offline
            Pout
            It's like this:
            The webdialog is opened though a button and shows info on the Sketchup model.
            Straightforward, no class used.
            So i think it's the AppObserver i need.
            I have to initiate that at the start of the ruby and just handle the events?
              Yup!
                class MyDialogAppObserver < Sketchup;;AppObserver
                  def onNewModel(model)  ### from menu or app
                    begin
                      $myDialogID_12345.close
                    rescue
                  def onOpenModel(model) ### from menu
                    begin
                    rescue
                  def onQuit()
                    begin
                    rescue
                ### Attach the observer at kick-off...
                Sketchup.add_observer(MyDialogAppObserver.new)
                You then need to set a global variable referring to your dialog [ dlg] so the observer can find and close it...
                $myDialogID_12345=dlg
                  Beware that on OSX you can have multiple model documents open.
                  • P Offline
                    Pout
                    Tig, thx for the piece of code!
                    ThomThom, in that case it think it will be necessary to keep the model path in a global variable and use that to check.
                      And if the user swaps between models while working?
                      Or the user saves the model under a new name?
                      I have a tool where I need to keep track of the various models. I tried using the model object as reference, but it changes when you save teh model etc. I also tried the model.guid - but that also changes at times. At the moment I use a combo of model object and guid to track it.
                      • P Offline
                        Pout
                        sssshtttt ThomThom,
                        you're giving me a headache on a friday afternoon 😆
                          Why not make a simple tool that opens the dialog and then you can have a 'deactivate()' method to close the dialog whenever you move away from that SKP ? - you'd just need to wrap the original 'def' code into an initialize()/activate() instead, inside the new tool's class and call the 'tool' in a slightly different way from a raw 'def' ??
                          Adding convoluted observers and global variables seems to be a lot more complicated...
                            Then you can't use the other native tools.
                            (And I'd use module variables instead of global variables.)
                              @pout said:
                              sssshtttt ThomThom,
                              👿 you're welcome. 😄
                              The whole multiple window scenario under OSX is a bit of a pain - I don't feel it has proper support in the API for managing them.
                              • Dan RathbunD Offline
                                Dan Rathbun
                                Agreed.
                                I logged several Feature Requests for MDI support (new methods) in the API, including a Models collection.
                                I'm not here much anymore.
