    Close webdialogs on File-New/Open
    14 Posts 4 Posters 1.2k Views 4 Watching
      @pout said:
      I have to initiate that at the start of the ruby and just handle the events?
      Yup!
        class MyDialogAppObserver < Sketchup;;AppObserver
          def onNewModel(model)  ### from menu or app
            begin
              $myDialogID_12345.close
            rescue
          def onOpenModel(model) ### from menu
            begin
            rescue
          def onQuit()
            begin
            rescue
        ### Attach the observer at kick-off...
        Sketchup.add_observer(MyDialogAppObserver.new)
        You then need to set a global variable referring to your dialog [ dlg] so the observer can find and close it...
        $myDialogID_12345=dlg
          Beware that on OSX you can have multiple model documents open.
            Pout
            Tig, thx for the piece of code!
            ThomThom, in that case it think it will be necessary to keep the model path in a global variable and use that to check.
              And if the user swaps between models while working?
              Or the user saves the model under a new name?
              I have a tool where I need to keep track of the various models. I tried using the model object as reference, but it changes when you save teh model etc. I also tried the model.guid - but that also changes at times. At the moment I use a combo of model object and guid to track it.
                Pout
                sssshtttt ThomThom,
                you're giving me a headache on a friday afternoon πŸ˜†
                  Why not make a simple tool that opens the dialog and then you can have a 'deactivate()' method to close the dialog whenever you move away from that SKP ? - you'd just need to wrap the original 'def' code into an initialize()/activate() instead, inside the new tool's class and call the 'tool' in a slightly different way from a raw 'def' ??
                  Adding convoluted observers and global variables seems to be a lot more complicated...
                    Then you can't use the other native tools.
                    (And I'd use module variables instead of global variables.)
                      @pout said:
                      sssshtttt ThomThom,
                      πŸ‘Ώ you're welcome. πŸ˜„
                      The whole multiple window scenario under OSX is a bit of a pain - I don't feel it has proper support in the API for managing them.
                      • Dan RathbunD Offline
                        Dan Rathbun
                        Agreed.
                        I logged several Feature Requests for MDI support (new methods) in the API, including a Models collection.
                        I'm not here much anymore.
