    Close webdialogs on File-New/Open
    14 Posts 4 Posters 592 Views 4 Watching
      Pout
      Is there a way to observe if the user opens a new or existing file so the open webdialogs can be closed?
        You shouldn't need an observer if the tool-class calling the dialog [ @dlg] has a deactivate() method which includes @dlg.close if @dlg and @dlg_is_open or equivalent. Exiting the tool then closes the dialog if it has been set up initially and is still 'open'. The instance variable @dlg_is_open can be set true/ false as you open and then close the dialog @dlg.
        If you have closed the dialog in the Tool then later call self.deactivate() etc...
        You should also use it in the onCancel() method too...
        Alternatively the code
        begin @dlg.close rescue end
        does it trapping errors for you in the deactivate() ???
        Of course on a PC opening your dialog so it is 'modal' with '@dlg.show_modal{#what_to_do#}' prevents you even exiting the Tool or the SKP until the dialog is closed itself.
          That's assuming the webdialog is opened by a tool. If it isn't, then it's the AppObserver one has to use: http://code.google.com/apis/sketchup/docs/ourdoc/appobserver.html
            Pout
            It's like this:
            The webdialog is opened though a button and shows info on the Sketchup model.
            Straightforward, no class used.
            So i think it's the AppObserver i need.
            I have to initiate that at the start of the ruby and just handle the events?
              Yup!
                class MyDialogAppObserver < Sketchup;;AppObserver
                  def onNewModel(model)  ### from menu or app
                    begin
                      $myDialogID_12345.close
                    rescue
                  def onOpenModel(model) ### from menu
                    begin
                    rescue
                  def onQuit()
                    begin
                    rescue
                ### Attach the observer at kick-off...
                Sketchup.add_observer(MyDialogAppObserver.new)
                You then need to set a global variable referring to your dialog [ dlg] so the observer can find and close it...
                $myDialogID_12345=dlg
                  Beware that on OSX you can have multiple model documents open.
                    Pout
                    Tig, thx for the piece of code!
                    ThomThom, in that case it think it will be necessary to keep the model path in a global variable and use that to check.
                      And if the user swaps between models while working?
                      Or the user saves the model under a new name?
                      I have a tool where I need to keep track of the various models. I tried using the model object as reference, but it changes when you save teh model etc. I also tried the model.guid - but that also changes at times. At the moment I use a combo of model object and guid to track it.
                        Pout
                        sssshtttt ThomThom,
                        you're giving me a headache on a friday afternoon 😆
                          Why not make a simple tool that opens the dialog and then you can have a 'deactivate()' method to close the dialog whenever you move away from that SKP ? - you'd just need to wrap the original 'def' code into an initialize()/activate() instead, inside the new tool's class and call the 'tool' in a slightly different way from a raw 'def' ??
                          Adding convoluted observers and global variables seems to be a lot more complicated...
                            Then you can't use the other native tools.
                            (And I'd use module variables instead of global variables.)
                              @pout said:
                              sssshtttt ThomThom,
                              👿 you're welcome. 😄
                              The whole multiple window scenario under OSX is a bit of a pain - I don't feel it has proper support in the API for managing them.
                              • Dan RathbunD Offline
                                Dan Rathbun
                                Agreed.
                                I logged several Feature Requests for MDI support (new methods) in the API, including a Models collection.
                                I'm not here much anymore.
