    GIMP
    23 Posts 12 Posters 1.6k Views 12 Watching
    • V Offline
      Viztecture
      Recently downloaded GIMP to have a look, see what the crack is after having problems with my PS. I've just got to say its bloody frustrating. I understand its free and its ok for basic stuff but for compiling a render and the level of post I normally do its a pain in the arse!
      The tools seem fairly powerful but the interface and toolbars make the process akin to eating a cream cake with boxing gloves. Am I just not getting it or does anyone feel the same? πŸ‘Š
      http://www.viztecture.mfbiz.com
      • numbthumbN Offline
        numbthumb
        πŸ˜„
        I had the same feeling when I tried to learn Blender...
        Comfortably numb...
          I also hate the UI (and that all the flying windows get stacked and hidden by each other or other windows all the time).
          It's a Linux thing I guess.
          • Rich O BrienR Online
            If find it gets too hot under the mask
            http://www.marieclaire.com/cm/marieclaire/images/gimp_3.jpg
            Sorry, wrong forum πŸ˜•
            • V Offline
              Viztecture
              http://t3.gstatic.com/images?q=tbn;8oUDxETCrsAaQM;http://movieimage1.tripod.com/pulpfiction/pulp15.jpg&t=1
              this is how i currently feel...
                tfdesign
                Took the picture right out of my mind!!
                I use an image editor called "Pixelmator" for the majority of my work. But it's Mac-only.
                You could try "Paint.net", which is very good, and works with Windows only. And it's free. GIMP is okay, but it has a really steep curve (like Blender). The bottom line is though, there is nothing to beat Photoshop really 😞
                My book "Let's SketchUp!" Download from here
                  I would second Paint.NET. It may not have all of the ability that PS has, it seems to be quite capable and the interface is straight-forward. I use it instead of PS often just because it opens much faster.
                  • V Offline
                    Viztecture
                    not heard of paint.net...il have a look cheers
                      dedmin
                      Other way around is the same - from GIMP to Photoshop! Or from Blender to MAX. Or from Socialism to Capitalism and "Democracy"! It is very simple - give Gimp the same amount of time as your other editor and then compare! There are a lot of complaints about SketchUP to be clunky from power Max users.
                        Aerilius
                        I actually hated Gimp - at least as much as you disliked it at the first moment.
                        Then after some months I had to use it by lack of alternatives and actually - if you give it a try - you can learn to use it as efficient as any commercial program. When I return sometimes to the program that I had used before (PaintShop Pro) I feel it lacks many tools that I am now used to.
                        Paint.Net is also a good program.
                        If you really want to use Gimp, I recommend that you take an hour to go through all settings and preferences. Then you will feel immediately more comfortable than trying to learn the default settings for weeks. Change the settings to what you are used to or what you think is reasonable.
                        Change the mouse wheel to zoom instead of scroll. Then set up the toolbox, window positions, brushes and save it as default in preferences->window management and preferences->toolbox settings.
                        We cannot compare it with commercial programs, especially the development is slower than I would like. Selections behave very different. The menus are still a bit bloated. The flying windows issue will be solved in GIMP2.8 (2011). I felt that many tools are more powerfull, they combine what other programs need several tools for.
                        And all shortcuts follow a quite reasonable principle:
                        select all: ctrl+A
                        clear selection: ctrl+A+shift (SketchUp: ctrl+T, PSP: ctrl+D...)
                          danbig
                          I'm a fan of GIMP. And Inkscape. With both of them, the learning curve is a bit steep.
                          Paint.net is great, I use it daily, but it's not really an alternative to GIMP or PS, if you're using anything beyond the very most basic tools.
                          • utilerU Offline
                            utiler
                            Hey Dan, I too like GIMP but haven't spent the time learning it properly.... It gets me by with what I want it for. I'm hoping the UI gets a little easier to handle in the next release though.
                            I guess I can't complain; it is free. 😎
                            Just Curious...
                              dedmin
                              Some Gimp tutorials
                              http://meetthegimp.org/tables-of-content/
                              http://sixrevisions.com/graphics-design/gimp_video_tutorials/
                              • utilerU Offline
                                utiler
                                cool, dedmin.....Ta.
                                πŸ‘
                                Just Curious...
                                • P Offline
                                  Panga
                                  With the last dev version, GIMP 2.7.1, There's an option that enable "single window mode"...no more floating pannels...I definitly gave up PS for this version of Gimp.
                                  http://sourceforge.net/projects/gimp-win/files/GIMP%20%2B%20GTK%2B%20%28development%20rel.%29/GIMP%202.7.1/gimp-2.7.1-setup.exe/download
                                  Cheers.
                                    dedmin
                                    And more
                                    http://www.chromecode.com/2009/10/single-window-mode-progress-report.html
                                    http://meetthegimp.org/gimp-2-7-1-released/
                                      Hi Panga and thanks for the tip! I downloaded it and I like it (although unfortunately it does not save this state of the window on exit - YET? - so I always have to set it and adjust the width of some toolbars every time I load Gimp)
                                      • utilerU Offline
                                        utiler
                                        @panga said:
                                        With the last dev version, GIMP 2.7.1, There's an option that enable "single window mode"...no more floating panels...I definitly gave up PS for this version of Gimp.
                                        Cheers.
                                        Gee, I didn't know this had been released.... Cheers!!
                                        The single window mode is what's been missing.... πŸ‘
                                        Just Curious...
                                        • P Offline
                                          Panga
                                          Yes Gaieus, It's a known bug in windows version. But even with that, I do not regret Photoshop at all...What a pity the gimp dev team did not make this single window feature sooner !! And Now I've got my perfect couple of software for working : Gimp and Inkscape (another awesome application). I think that future version of Gimp'll have vector support, including ability to open SVG files from Inkscape !
                                          Cheers.
                                          • michaliszissiouM Offline
                                            michaliszissiou
                                            What gimp has to do with blender? Two different apps, what's funny is that we (blender people) wish to make it look like blender one day. Now blender is more capable for PP via nodes. Nodes, something what Ps users haven't even in their dreams.
                                            You have to spend some time learning these apps. At least the same time you spent to learn Ps. Gimp is fine. Learn it first. As for blender, well SU people, its not for you. As is LW, maya, modo etc etc... 😎
                                            The magic wang, out of the magic castle, is just a wooden stick. (Wittgenstein)
                                            • 1 / 2
