    Error when manually entering color. SU8
    9 Posts 4 Posters 1.5k Views 4 Watching
      DIEGO-RODRIGUEZ
      windows xpsp3 español
      sketchup 8 español
        What is the error message? (I can only see part of it).
        But indeed, mine (English) also gives an error message but that's correct. When using the RGB values, they must be between 0 and 255 and you are entering 521 in the red channel.
          DIEGO-RODRIGUEZ
          yes, I know Gaieus
          but, the problem is when enter the numbers back to front. 😄
          for example if I enter 125
          I write the number 521
          • ely862meE Offline
            ely862me
            Maybe is ur keyboard or ur system that cause the reversed typing .
            Elisei (sketchupper)
            Come and See EliseiDesign
              DIEGO-RODRIGUEZ
              Strange.
              in sketchup 7, everything works fine
              in sketchup 8, does not work
                ah, I see, okay. If that wasn't intentional, it's weird indeed (as if Spanish were a rtl language)
                  Do you by any chance have VfSU installed? I think the recent version interfere with the input of colours.
                    DIEGO-RODRIGUEZ
                    yes thom. I'm using the beta-test version 1.48.94
                    if the problem is with vray.
                    delete vfs.rb file and now the colors work fine.
                    would have to report this error to the company vray, no?
                      Yes, report this.
                      Btw, no need to delete vfs.rb - just disable VfSU under extensions.
                      (If you keep VfSU disabled under extensions you can use V-Ray Toys to load VfSU on demand when you need it.)
