Error when manually entering color. SU8
9 Posts 4 Posters 1.1k Views 4 Watching
    DIEGO-RODRIGUEZ
    windows xpsp3 español
    sketchup 8 español
      What is the error message? (I can only see part of it).
      But indeed, mine (English) also gives an error message but that's correct. When using the RGB values, they must be between 0 and 255 and you are entering 521 in the red channel.
        DIEGO-RODRIGUEZ
        yes, I know Gaieus
        but, the problem is when enter the numbers back to front. 😄
        for example if I enter 125
        I write the number 521
        • E Offline
          ely862me
          Maybe is ur keyboard or ur system that cause the reversed typing .
          Elisei (sketchupper)
          Come and See EliseiDesign
            DIEGO-RODRIGUEZ
            Strange.
            in sketchup 7, everything works fine
            in sketchup 8, does not work
              ah, I see, okay. If that wasn't intentional, it's weird indeed (as if Spanish were a rtl language)
                Do you by any chance have VfSU installed? I think the recent version interfere with the input of colours.
                  DIEGO-RODRIGUEZ
                  yes thom. I'm using the beta-test version 1.48.94
                  if the problem is with vray.
                  delete vfs.rb file and now the colors work fine.
                  would have to report this error to the company vray, no?
                    Yes, report this.
                    Btw, no need to delete vfs.rb - just disable VfSU under extensions.
                    (If you keep VfSU disabled under extensions you can use V-Ray Toys to load VfSU on demand when you need it.)
