    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 474.8k Views 75 Watching
    • jamalitoJ Offline
      jamalito
      wow every good I like this plugin
      becouse I am used it in ornamentation
      thnx
      Albert Einstein:
      ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
        Ben Ritter
        Thomas, I love it. I have the mesh made, but struggling to find the right image size to make the mesh workable. I've broken the image down into 6 parts and I have a mesh, but can't get a texture applied. SU crashes.
        I've been able to apply the texture when it's grouped, but the image gets applied rotated 180 deg.
        So, for anyone, is there a way to simplify the mesh first? Would that actually help in applying the projected texture?
        SU8.0.3117, File is 98mb
          Matias Germán
          It´s a great plugin. Thanks Thomas. 👍
            If you need a simpker mesh, resample the bitmap you generated it from down. Less pixels - simpler mesh.
              Ben Ritter
              I will try the resampling. Any idea why the image gets turned around?
                Got a screenshot? I'm not sure if I understand what you describe.
                • majidM Offline
                  majid
                  Dear tomtom, I'ven;t tested your plugin yet, seems to be great and so many thanx, but as a suggestion to reduce faces and improvement, maybe you could add an option for merging co-planar faces
                    Ben Ritter
                    Thomas, thanks for your help, I can't seem to recreate that scenario now, but here's what happens when I try to project the texture above it. I get bits and pieces onto the mesh.
                      You could run CleanUp afterwards.
                      • FletchF Offline
                        Fletch
                        Ben, look at my example of roof tile above very closely - you will see that you should use a TINY .bmp... I mean TINY.
                        Then scale the mesh that is generated UP in SketchUp, then PROJECT your texture DOWN onto the face. Be sure the texture position is set to PROJECTED.
                        Remember that BLACK is the lowest point, and WHITE is the HIGHEST point on the final mesh... so make sure to create your displacement map appropriately... a sketch like that is not likely to give you the exact results you want... depending on what you want I guess.
                        Thom Thom, I used your plugin to helpme create this image... thanks again! 👍
                        It is KEY to use a very good displacement map and very small resolution.
                        Fletch
                        3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                          Fletch - how did you do that?
                          A plugin that inserts components at vertices?
                            Fletch, that is way cool! It looks like an On/Off button but makes me think it's label could be changed by controlling which pins are up and which are down.
                              Ben Ritter
                              Fletch, thanks for the reminders. The bmp was a scanned in sketch that I tried. Perhaps not the best to use. Thank you anyway.
                                Here is a bit of the workflow.
                                http://twilightrender.com/phpBB3/viewtopic.php?f=26&t=2208
                                  The board requires you to be registered and logged in to view this forum.
                                    Ah yeah, that is a restricted area for license holders.
                                    Anyway, it's drop.rb. 😉
                                      Version 0.3.0b
                                      • Renamed Mesh From Bitmap to Mesh From Heightmap
                                      • Added new Mesh From Bitmap
                                        [attachment=0:3etwkcol]<!-- ia0 -->MeshFromBitmap.png<!-- ia0 -->[/attachment:3etwkcol]
                                      Known bug:
                                      Flipped image isn't properly recognised.
                                        jeffschaid01
                                        Hello,
                                        After importing the bmp, I've adjusted height, width, etc. The program then follows through by indexing points and generating a mesh. After that I'm attempting to export as a vrml and the program continues to crash at 49%. I'm sure doing something incorrectly but not sure what. Any suggestions?
                                        Thanks,
                                        Jeff
                                          jeffschaid01
                                          Hello,
                                          Are further steps needed prior to exporting as vrml after height, width and depth adjustments have been made along with point indexing and mesh generating? All of these steps have been completed but SU is crashing at the 49% mark while exporting as vrml. Any help will be greatly apprecaited.
                                          Thanks,
                                          Jeff
                                            VRML? What are you using to export that?
                                            • 6
                                            • 7
                                            • 8
                                            • 13
                                            • 14
                                            • 6 / 14
