    Tree Clipping 'white edging' issue
    renderpluginsextensions
    5 Posts 4 Posters 1.5k Views 4 Watching
      Scostumatu
      PLs see below render, everytime i render the trees (using the method of adding the alpha image in transperancy) I seem to be getting a weird 'white edging' effect around the trees. Particulary the tree on the far left and on the far right near the garage door. Is there a way to eliminate this within sketchup/vray?
      Using Sketchup 7.1 and Vray 1.05.30
        sorgesu
        Just in case,
        Styles>Edit>Face Settings Enable Transparency (ticked) Transparency Quality > NICER
        Yes?
        Susan Sorger
        • EarthMoverE Offline
          EarthMover
          It's probably more related to the resolution of the image and the accuracy at which it was "cut out" originally. It's really a tough fix and one that I typically will cheat post render in photoshop. Typically using a combination of the burn tool and replace color.
          Susan tip is great for Sketchup renders, but doesn't help with how Vray is reading the pixel data.
          Content Creator at Skapeup
            tomsdesk
            Try setting the image transparency to 98%...sure helps my tree png's.
            2.5D Trees & Shrubs!
              Scostumatu
              Thanks to you both.
              Tom - im at work so I dont have access to my programs. By transparancy do you mean adjusting it within the transparancy option thats next to the diffuse option within the materials editor in Vray? ie sliding it from white into the black by 2%?
