    SketchyPhysics3.1
    85 Posts 37 Posters 86.5k Views 37 Watching
      CPhillips
      Here is the long awaited new version of SP. Hopefully this version will be much more stable under SU8.
      Error 404 (Not Found)!!1
      (code.google.com)
      Check out the Release Notes for changes:
      http://code.google.com/p/sketchyphysics/wiki/ReleaseNotes3_1
      All the scripted events and commands. This list will get fleshed out over time.
      http://code.google.com/p/sketchyphysics/wiki/ScriptFunctions
      Mac version, more docs and examples to follow....
      Updated Oct 7 2010
      Changes:
      http://code.google.com/p/sketchyphysics/wiki/SP31Oct7
      • P Offline
        phy
        SWEET!!!!!!!!! ๐Ÿ˜
        Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
        • KrisidiousK Offline
          Krisidious
          is this for SU7 too?
          By: Kristoff Rand
            CPhillips
            Yes it will run under SU7. Just change the location its installed to.
              CPhillips
              Here is an example of something I just added recently. A script function that allows you to get a point along a Sketchup curve. It can be used for any number of things. In this case I use it to move bodies along a curve.
              CurvesTest3.skp
                CPhillips
                Another curve example. This time the curve is used to set the position (via controller field) of a pair of pistons.
                CurveControllers1.skp
                  CPhillips
                  This example shows off several features. Embedded sounds, destroying bodies during simulation, logging messages to the screen, camera following a target and lots of ontouch features.
                  WhiteboxLogic6.skp
                    CPhillips
                    Here are some older examples that now work in this official release version.
                    http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168251
                    http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168253
                    http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168254
                    http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168265
                      mptak
                      Yipee...Yapee...Yahooeee!
                        mrmar975
                        Thank you! I am a teacher using this for my robotics class. The design abilities and creativity I get to engage my students in is amazing, thanks to you. Much appreciated.
                          dmondark
                          Standing by for the mac "version"...
                          ๐Ÿ˜Ž
                          • H Offline
                            hobbnob
                            How do we go about using the sound function? I tried using the playSound script but it didn't work.
                            Here's the file, please tell me what's wrong.
                            sound test.skp
                            My WIP Thread:Here
                              jblively
                              On the self Connecting Joints Example, can you add a name of a slider in there, so there can be a way to control the joints via the control panel?
                              ontouch{|t,s,p|
                              connect(t,"servo")
                              ontouch{}
                              I didn't see it in this Definition: connect(child,type="ball",min=0,max=0,accel=0,damp=0,breakingForce=0)
                              I'll never draw another dang joint again if this works ๐Ÿ˜‰
                                Mr.K.1
                                It seem you didn't embed the sound, which this function needs because it doesn't play it directly from file, but from embedded sound data.
                                What you do is go to Plugins -> SketchyPhysics -> Sound, and it should open up a simple UI to add/embed sound, and later on don't forget to save your model so the data get's saved with it.
                                  CPhillips
                                  Turns out the break example will bugsplat SU8. I have a fix but I am going to wait and see if there are any other issues before I release a new version.
                                    CPhillips
                                    ontouch{|t,s,p|
                                    connect(t,"servo")
                                    ontouch{}
                                    Thats a bit harder than it sounds. But I will look into it.
                                      CPhillips
                                      Ah! Turns out to be easier than I thought. This will work in next version:
                                      !!!Example only. Will not work in Sept 27 version!!!
                                      ontouch{|t,s,p|
                                         @jnt=connect(t,"servo",0,90)
                                         ontouch{}
                                      ontick{
                                         if @jnt!=nil
                                            @jnt.controllerValue=slider("position")
                                        CPhillips
                                        Updated the scripting reference. Not done yet, but more usable now.
                                        (code.google.com)
                                        • H Offline
                                          hobbnob
                                          Well on the whole this is a very much improved release, K's advice for embedding sounds worked fine and I've also tried out the destroy function, very useful for so many things.
                                          My WIP Thread:Here
                                            jblively
                                            Excellent!!!!!
                                            Can't Wait ๐Ÿ˜„
                                            • 1 / 5
