    SketchyPhysics3.1
    85 Posts 37 Posters 87.7k Views 37 Watching
    • KrisidiousK
      Krisidious
      is this for SU7 too?
      By: Kristoff Rand
      • C
        CPhillips
        Yes it will run under SU7. Just change the location its installed to.
        • C
          CPhillips
          Here is an example of something I just added recently. A script function that allows you to get a point along a Sketchup curve. It can be used for any number of things. In this case I use it to move bodies along a curve.
          CurvesTest3.skp
          • C
            CPhillips
            Another curve example. This time the curve is used to set the position (via controller field) of a pair of pistons.
            CurveControllers1.skp
            • C
              CPhillips
              This example shows off several features. Embedded sounds, destroying bodies during simulation, logging messages to the screen, camera following a target and lots of ontouch features.
              WhiteboxLogic6.skp
              • C
                CPhillips
                Here are some older examples that now work in this official release version.
                http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168251
                http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168253
                http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168254
                http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168265
                  mptak
                  Yipee...Yapee...Yahooeee!
                    mrmar975
                    Thank you! I am a teacher using this for my robotics class. The design abilities and creativity I get to engage my students in is amazing, thanks to you. Much appreciated.
                      dmondark
                      Standing by for the mac "version"...
                      • H
                        hobbnob
                        How do we go about using the sound function? I tried using the playSound script but it didn't work.
                        Here's the file, please tell me what's wrong.
                        sound test.skp
                        My WIP Thread:Here
                          jblively
                          On the self Connecting Joints Example, can you add a name of a slider in there, so there can be a way to control the joints via the control panel?
                          ontouch{|t,s,p|
                          connect(t,"servo")
                          ontouch{}
                          I didn't see it in this Definition: connect(child,type="ball",min=0,max=0,accel=0,damp=0,breakingForce=0)
                          I'll never draw another dang joint again if this works πŸ˜‰
                            Mr.K.1
                            It seem you didn't embed the sound, which this function needs because it doesn't play it directly from file, but from embedded sound data.
                            What you do is go to Plugins -> SketchyPhysics -> Sound, and it should open up a simple UI to add/embed sound, and later on don't forget to save your model so the data get's saved with it.
                            • C
                              CPhillips
                              Turns out the break example will bugsplat SU8. I have a fix but I am going to wait and see if there are any other issues before I release a new version.
                              • C
                                CPhillips
                                ontouch{|t,s,p|
                                connect(t,"servo")
                                ontouch{}
                                Thats a bit harder than it sounds. But I will look into it.
                                • C
                                  CPhillips
                                  Ah! Turns out to be easier than I thought. This will work in next version:
                                  !!!Example only. Will not work in Sept 27 version!!!
                                  ontouch{|t,s,p|
                                     @jnt=connect(t,"servo",0,90)
                                     ontouch{}
                                  ontick{
                                     if @jnt!=nil
                                        @jnt.controllerValue=slider("position")
                                  • C
                                    CPhillips
                                    Updated the scripting reference. Not done yet, but more usable now.
                                    Error 404 (Not Found)!!1
                                    (code.google.com)
                                    • H
                                      hobbnob
                                      Well on the whole this is a very much improved release, K's advice for embedding sounds worked fine and I've also tried out the destroy function, very useful for so many things.
                                      My WIP Thread:Here
                                        jblively
                                        Excellent!!!!!
                                        Can't Wait πŸ˜„
                                          jblively
                                          (code.google.com)
                                          WOW!
                                          I know how it's not fun to doc (i've done my share) but I know we all will really appreciate this new format. Very readable and usable! Great Job!
                                          • C
                                            CPhillips
                                            Version delayed while I deal with a family issue.
                                            • 1 / 5
