    SketchyPhysics3.1
    85 Posts 37 Posters 82.5k Views 37 Watching
      ROVAP
      Am I being stupid but could someone put a link directly to the latest MAC version of SP 3.1 or 3.2 what ever is latest. I often read the forums and see Mac version coming then the next posts are of people trying to get Mac version to work. However I never see the link or if there is one it takes you to a PC exe file.
      Thanks in advance. 😲
        solodown
        Error Loading File sketchyphysics.rb
        dlopen(/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib, 9): no suitable image found. Did find:
        /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL.dylib: unknown required load command 0x80000022
          cljohnston108
          Good question. I tried downloading SketchyPhysics3RC1-MacAndWin-Fixed.zip off the Wiki front page, but the newest files in there are dated March 26, 2009, so I figured that can't be right.
            CPhillips
            Sorry for the late reply. Mac will be supported in the next version. It was supposed to be out last week but I found some problems and havent had a chance to fix them. It should be in a few days.
              cljohnston108
              Coolness! Looking forward to it!
                Davidfi1
                Guys
                Could you please "STICK" this final version on the top of the forum?
                Thank you all very much.
                Good work!
                David.
                  arjunmax09
                  where can i get tutorial for sketchyphysics...maybe a pdf file...??
                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    cljohnston108
                    Any progress?
                      dorritos
                      @cljohnston108 said:
                      Any progress?
                      How 'bout now? 😄
                        CPhillips
                        Sorry, I know I am late with the new version. I have been real busy.
                        I'll work on this week but no promises.
                          loolytoo
                          I downloaded the newest version of sketchy physics and installed it. I have sketchup pro 8. When sketch up starts i get the following message
                          undefined method extend_object' for Singleton'
                          then when i try to download and use a sketchy physics model from wharehouse, they dont work and i get the following message.
                          Error starting the simulation:uninitialized constant. msketchyphysics 3::SP3xSimulationContext::SP Sounds C:/PROGRA~1/google/GOOGLE~3/plugins/sketchyphysics3/controller commands. Rb:777:in 'initialize'
                          can anyone help me with how i sort this out?
                          Lucy
                            CPhillips
                            I have never seen that error before. Best guess something went wrong with the new Midi sound support. What version of windows are you using? Do you have any thing unusual about your sound setup?
                              andy1347
                              I get the exact same error as Loolytoo above. The only apparent difference is I am using Windows 7 Pro 64 bit and SU7. I have tried reinstalling SketchyPhysics. When I run a sample model, the Ruby console shows this;
                              Checking if dueForUpdate
                              String doesn't compile: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds#<NameError: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds>
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in new'
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in new'
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in startphysics' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in physicsTogglePlay'
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1737:in `call'
                              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SKMtools/image_class.rb:946
                              Had I made this model myself, I would say it is operator error, but that is not the case.
                              Could someone shed some light on how to either solve this or work around it so I could try my hand at using this plug-in?
                              Thanks,
                              Andy
                                CPhillips
                                64 bit might be the problem. It looks like the scripts are not loading properly so the bug is probably happening before the error you submitted.
                                Try this:
                                Load Sketchup
                                Open the ruby console under the windows menu.
                                Then type this:
                                load('sketchyphysics.rb')
                                It will probably print an error. If so send it to me and I can track it down.
                                Chris
                                  andy1347
                                  Hi Chris,
                                  I did as you suggested (I hope).
                                  After disabling Sketchyphysics from the plug-in menu, restarting SU and entering the statement, I got this;
                                  true
                                  If I then restart sketchyphysics from the plug-in menu, the console gives this;
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/hinge.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/slider.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/servo.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/piston.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/motor.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/gyro.png
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/Images/fixed.png
                                  createSelectionObserver
                                  PhysicsObjectInspector initialized
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Tools
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/ruby
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/JimFoltz
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Podium
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SuTool/rb/
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SuTool/ro/
                                  loading scripts version:45
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/midiator
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/singleton.rb:124: warning: already initialized constant FirstInstanceCall
                                  Error: #<NameError: undefined method extend_object' for Singleton'>
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/singleton.rb:166:in undef_method' C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/singleton.rb:166 C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/driver_registry.rb:17:in require'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/midiator.rb:29:in require' C:/Program Files (x86)/Google/Google SketchUp 7/plugins/SketchyPhysics3/midiator/lib/midiator/midiator.rb:29 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/midi.rb:6:in require'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:33:in load' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:33:in LoadSketchyPhysics3'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:61:in doLoad' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:43:in setLoadVersion'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:93
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:93:in `call'
                                  If I then load a model and try to run it, I get the error reported a couple of posts above "....777.." and the console gives this;
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/sketchyphysics.rb:93:in call' Error: #<NoMethodError: undefined method []' for nil:NilClass>
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SKMtools/image_class.rb:946:in onOpenModel' Error: #<NoMethodError: undefined method []' for nil:NilClass>
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SKMtools/image_class.rb:946:in onOpenModel' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SKMtools/image_class.rb:946 open model#<Sketchup::Model:0x106577f0> createSelectionObserver PhysicsObjectInspector initialized Checking if dueForUpdate String doesn't compile: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds#<NameError: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in initialize'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in new' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in initialize'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in new' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in startphysics'
                                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in physicsTogglePlay' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1737:in call'
                                  I'm not sure that will be much help, but thank you and let me know what you would like me to try next.
                                  Andy
                                    CPhillips
                                    Hmmmmm. It isnt obvious what the problem is from the log. But I dont think its a 64 bit problem.
                                    It might be a plugin conflict. Would you mind testing that?
                                    Copy your plugins directory so you can restore it after testing.
                                    Then get rid of everything but:
                                    SketchyPhysics.rb
                                    SketchySolids.rb
                                    win32api.so
                                    SketchyPhysics3\ <-directory.
                                    Then try again with the ruby console method.
                                    Thanks for helping track this down!
                                    Chris
                                      andy1347
                                      Ok-we are making progress!
                                      When I do as you suggested and start SU, I get the following:
                                      undefined method `file_loaded?' for main:Object
                                      But, once I clear this and start SU, I can load sketchyphysics through the console and run the model. At this point, the console gives this:
                                      true
                                      I'm guessing this second part is normal because after this I can run the model. I will spend some time this weekend loading plugins one at a time until I hit the error and then report back.
                                      Thanks for your help and this nifty script. I am happy to help as I am mostly an observer here with little opportunity to contribute.
                                      Andy
                                        Suggests that 'sketchup.rb' isn't loaded at that point.
                                        At the very start of 'sketchyphysics.rb' add the line
                                        require 'sketchup.rb'
                                        that should fix at least that one error - then hopefully the consequential ones too...
                                          andy1347
                                          TIG nailed the first part of the problem with his suggested fix.
                                          After rebuilding my plug-ins folder, I have determined the culprit causing the conflict is a ruby called 'singleton' in a folder called 'ruby'. As near as I can tell, it is used with Jim Foltz's 'autocenterpoint'.
                                          With that one file removed, SketchyPhysics seems to load and run just fine. I hope this helps and look forward to a fix.
                                          Thanks to both of you for your help with this.
                                          Andy
                                            daniele_rossi
                                            I have the same problem running SketchyPhysics3.2 on sketchup 7 and Mac OSX 10.5.8 on Intel Core 2 Duo:
                                            dlopen(/Users/dr/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib, 9): no suitable image found. Did find:
                                            /Users/dr/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib: unknown required load command 0x80000022
                                            • 3 / 5
