    SketchyPhysics3.1
    85 Posts 37 Posters 82.5k Views 37 Watching
      mptak
      Yipee...Yapee...Yahooeee!
        mrmar975
        Thank you! I am a teacher using this for my robotics class. The design abilities and creativity I get to engage my students in is amazing, thanks to you. Much appreciated.
          dmondark
          Standing by for the mac "version"...
          • H Offline
            hobbnob
            How do we go about using the sound function? I tried using the playSound script but it didn't work.
            Here's the file, please tell me what's wrong.
            sound test.skp
            My WIP Thread:Here
              jblively
              @cphillips said:
              Here are some older examples that now work in this official release version.
              http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168251
              http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168253
              http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168254
              http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168265
              On the self Connecting Joints Example, can you add a name of a slider in there, so there can be a way to control the joints via the control panel?
              ontouch{|t,s,p|
              connect(t,"servo")
              ontouch{}
              I didn't see it in this Definition: connect(child,type="ball",min=0,max=0,accel=0,damp=0,breakingForce=0)
              I'll never draw another dang joint again if this works πŸ˜‰
                Mr.K.1
                It seem you didn't embed the sound, which this function needs because it doesn't play it directly from file, but from embedded sound data.
                What you do is go to Plugins -> SketchyPhysics -> Sound, and it should open up a simple UI to add/embed sound, and later on don't forget to save your model so the data get's saved with it.
                  CPhillips
                  Turns out the break example will bugsplat SU8. I have a fix but I am going to wait and see if there are any other issues before I release a new version.
                    CPhillips
                    ontouch{|t,s,p|
                    connect(t,"servo")
                    ontouch{}
                    Thats a bit harder than it sounds. But I will look into it.
                      CPhillips
                      Ah! Turns out to be easier than I thought. This will work in next version:
                      !!!Example only. Will not work in Sept 27 version!!!
                      ontouch{|t,s,p|
                         @jnt=connect(t,"servo",0,90)
                         ontouch{}
                      ontick{
                         if @jnt!=nil
                            @jnt.controllerValue=slider("position")
                        CPhillips
                        Updated the scripting reference. Not done yet, but more usable now.
                        Google Code Archive - Long-term storage for Google Code Project Hosting.
                        (code.google.com)
                        • H Offline
                          hobbnob
                          Well on the whole this is a very much improved release, K's advice for embedding sounds worked fine and I've also tried out the destroy function, very useful for so many things.
                          My WIP Thread:Here
                            jblively
                            Excellent!!!!!
                            Can't Wait πŸ˜„
                              jblively
                              (code.google.com)
                              WOW!
                              I know how it's not fun to doc (i've done my share) but I know we all will really appreciate this new format. Very readable and usable! Great Job!
                                CPhillips
                                Version delayed while I deal with a family issue.
                                  Davidfi1
                                  Wonderful Work !!!
                                  Thank you.
                                  the http://forums.sketchucation.com/viewtopic.php?f=61&t=24201#p206890 bug is not fixed yet but it is not that interesting
                                    CPhillips
                                    New version is up here:
                                    http://code.google.com/p/sketchyphysics/downloads/list
                                    Changes:
                                    http://code.google.com/p/sketchyphysics/wiki/SP31Oct7
                                    Once a few people verify it works I'll turn on the auto update feature.
                                    Update:
                                    I have enabled the autoupdate. Hopefully it works. Some of the first few people who downloaded may have to update again as I forgot to change the version.
                                      phy
                                      @cphillips said:
                                      Update:
                                      The auto update worked great.
                                      Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                                        jblively
                                        Auto update works like a charm.
                                        I have having a bit of troubles with the auto connecting Joints and the Slider. I can get the slider to show up, but I can't get it to react to the slide when I move it. I'm using a motor joint, maybe that's the issue?
                                        I've attached a very simple sample, can you see what I might be doing wrong?
                                        Here is the joint code I am using:
                                        ontouch{|t,s,p|
                                        @jnt=connect(t,"motor",0,0,1,0.5)
                                        ontouch{}
                                        ontick{
                                        if @jnt!=nil
                                        @jnt.controllerValue=slider("motor",0)
                                        Thanks,
                                        Joe
                                        gears2.skp
                                          CPhillips
                                          Ah, i forgot about the motor joint. Ill fix in next version.
                                            jblively
                                            Thanks! Thought I was going a little crazy!
                                            • 1 / 5
