    SketchyPhysics3.1
    85 Posts 37 Posters 82.2k Views 37 Watching
      CPhillips
      Here are some older examples that now work in this official release version.
      http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168251
      http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168253
      http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168254
      http://forums.sketchucation.com/viewtopic.php?f=61&t=20209&start=0#p168265
        mptak
        Yipee...Yapee...Yahooeee!
          mrmar975
          Thank you! I am a teacher using this for my robotics class. The design abilities and creativity I get to engage my students in is amazing, thanks to you. Much appreciated.
            dmondark
            Standing by for the mac "version"...
            • H Offline
              hobbnob
              How do we go about using the sound function? I tried using the playSound script but it didn't work.
              Here's the file, please tell me what's wrong.
              sound test.skp
              My WIP Thread:Here
                jblively
                On the self Connecting Joints Example, can you add a name of a slider in there, so there can be a way to control the joints via the control panel?
                ontouch{|t,s,p|
                connect(t,"servo")
                ontouch{}
                I didn't see it in this Definition: connect(child,type="ball",min=0,max=0,accel=0,damp=0,breakingForce=0)
                I'll never draw another dang joint again if this works πŸ˜‰
                  Mr.K.1
                  It seem you didn't embed the sound, which this function needs because it doesn't play it directly from file, but from embedded sound data.
                  What you do is go to Plugins -> SketchyPhysics -> Sound, and it should open up a simple UI to add/embed sound, and later on don't forget to save your model so the data get's saved with it.
                    CPhillips
                    Turns out the break example will bugsplat SU8. I have a fix but I am going to wait and see if there are any other issues before I release a new version.
                      CPhillips
                      ontouch{|t,s,p|
                      connect(t,"servo")
                      ontouch{}
                      Thats a bit harder than it sounds. But I will look into it.
                        CPhillips
                        Ah! Turns out to be easier than I thought. This will work in next version:
                        !!!Example only. Will not work in Sept 27 version!!!
                        ontouch{|t,s,p|
                           @jnt=connect(t,"servo",0,90)
                           ontouch{}
                        ontick{
                           if @jnt!=nil
                              @jnt.controllerValue=slider("position")
                          CPhillips
                          Updated the scripting reference. Not done yet, but more usable now.
                          Google Code Archive - Long-term storage for Google Code Project Hosting.
                          (code.google.com)
                          • H Offline
                            hobbnob
                            Well on the whole this is a very much improved release, K's advice for embedding sounds worked fine and I've also tried out the destroy function, very useful for so many things.
                            My WIP Thread:Here
                              jblively
                              Excellent!!!!!
                              Can't Wait πŸ˜„
                                jblively
                                (code.google.com)
                                WOW!
                                I know how it's not fun to doc (i've done my share) but I know we all will really appreciate this new format. Very readable and usable! Great Job!
                                  CPhillips
                                  Version delayed while I deal with a family issue.
                                    Davidfi1
                                    Wonderful Work !!!
                                    Thank you.
                                    the http://forums.sketchucation.com/viewtopic.php?f=61&t=24201#p206890 bug is not fixed yet but it is not that interesting
                                      CPhillips
                                      New version is up here:
                                      http://code.google.com/p/sketchyphysics/downloads/list
                                      Changes:
                                      http://code.google.com/p/sketchyphysics/wiki/SP31Oct7
                                      Once a few people verify it works I'll turn on the auto update feature.
                                      Update:
                                      I have enabled the autoupdate. Hopefully it works. Some of the first few people who downloaded may have to update again as I forgot to change the version.
                                        phy
                                        @cphillips said:
                                        Update:
                                        The auto update worked great.
                                        Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                                          jblively
                                          Auto update works like a charm.
                                          I have having a bit of troubles with the auto connecting Joints and the Slider. I can get the slider to show up, but I can't get it to react to the slide when I move it. I'm using a motor joint, maybe that's the issue?
                                          I've attached a very simple sample, can you see what I might be doing wrong?
                                          Here is the joint code I am using:
                                          ontouch{|t,s,p|
                                          @jnt=connect(t,"motor",0,0,1,0.5)
                                          ontouch{}
                                          ontick{
                                          if @jnt!=nil
                                          @jnt.controllerValue=slider("motor",0)
                                          Thanks,
                                          Joe
                                          gears2.skp
                                            CPhillips
                                            Ah, i forgot about the motor joint. Ill fix in next version.
                                            • 1 / 5
