    [Plugin] Radial Lines
    24 Posts 8 Posters 14.7k Views 8 Watching
      (c) TIG 2010
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided that the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      radiallines.rb >>> ../Plugins/ folder
      Usage:
      Select one guide-point [cpoint] and some edges and/or faces
      then run Plugins menu ' Radial Lines...' sub-menu items...
      Lines- draws a line from the cpoint to each vertex.
      Lines [layered]- draws a line from the cpoint to each vertex, on Layer.
      Guides- draws a guide-line from the cpoint to each vertex.
      Guides with Lengths - draws a guide-line from the cpoint to each vertex,
      and adds central text to it showing its length,
      in current units.
      Donations:
      by PayPal to info @ revitrev.org PayPalButton ___________________________________________________________________________
      Version:
      1.0 20100923 First release.
      1.1 20100923 Line [layered] option added.
      ___________________________________________________________________________radiallines.rb
        Like this works like a charm πŸ˜‰ πŸ‘
        What about for have lines with a same lenght given on each lines? (say 2.23 m )
          Explain better... please
          Mieux expliquer...SVP
            davidlouis
            Working great but i see that is no layer functionality on the line only option 😞
            Please can you put it in so that one could have control over the generated entities for easy selection, visibility switches and deletion etc etc...
            Otherwise great work.... as always πŸ‘
            Dave
              I wish the red lines πŸ˜‰
              They will have all the same length!(2.23 m)
              http://forums.sketchucation.com/download/file.php?id=55001
                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=273614#p273614
                It now has an additional option 'Lines [layered]' - with this the Lines are put on their own layer rather than Layer0...
                  I think I see...
                  So if you used the 'Line' option the line would stop at a set length...
                  I'll think about it... πŸ€“
                    Many thx by advance β˜€ πŸ‘
                    Ps It's not possible to select also extremity points (like faces and segments)extremity.jpg
                      It will draw lines to both ends of any selected edges - you'll need to erase the unwanted lines...
                        There's now a separate script for drawing fixed length radial lines http://forums.sketchucation.com/viewtopic.php?p=273654#p273654
                          Damned you have a speedy coding method ! 😎
                          (I will use for the extremities not wanted if not too numerous πŸ’š
                          • mitcorbM Offline
                            mitcorb
                            How do you place the cpoint or guide point?
                            Error message keeps asking for this.
                            I thought by using measuring tape you could get a guide point.
                            Something I am not doing? Can't get this script to acknowledge the guide point, because it then wants a vertex?
                              Use the tools bar Projection by Didier Bur
                              There is a CPoint inside and some very useful tools!
                              • mitcorbM Offline
                                mitcorb
                                Thanks, Dave.
                                But I do not understand the conditions for guidepoint only. I usually get guidelines.
                                Thanks Pilou, I forgot about Didier's Projections. I have it on my home computer, but not here.
                                  then a vertex
                                  How dow you select one vertex from a single segment in the space? (extremity)
                                    A guide point is created when you measure off a point, vertex, intersection, etc. A guideline is created when you click on a line, edge or axis first.
                                    There are also some plugins like Point at Center and the Point cloud plugin that create guidepoints.
                                      Ben Ritter
                                      @dave r said:
                                      I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
                                      Dave, you hit the nail on the head. Remembering that when the time comes, you have such a helpful tool available.
                                      How do you all keep track of all the tools available in your SU arsenal, if they're not used on a regular basis?
                                      Ben
                                        Ben Ritter
                                        TIG, thank you very much. Again.
                                          Ben
                                          I gave up a long time ago, Ben. Periodically I look through my Plugins folder to see what treasures I've forgotten about. πŸ˜’ πŸ˜†
                                            i use projections and keep only the CPoint icon
                                            You have no keep The icone Extrude lines along a vector? β˜€
                                            • 1 / 2
