    [Plugin] Radial Lines
    24 Posts 8 Posters 16.0k Views 8 Watching
    • jeff hammondJ Offline
      jeff hammond
      re: construction point
      pay four bucks for the privilege of placing one
      http://www.smustard.com/script/AddConstructionPoint
      personally, i use projections and keep only the CPoint icon in my toolbar (next to draw construction lines which is another way to get a cpoint)
      with , start the measurement on an entity then click in blank space and you'll get a cpoint as well.
      [edit]- another way to get one without adding any rubies is to turn on 'ruby script examples' in the extensions preferences.. draw an arc the right-click on it and you'll have the option "Point at Center" in the context menu.. that will give a cpoint that can be moved around.
      dotdotdot
      • KrisidiousK Offline
        Krisidious
        do you ever sleep?
        By: Kristoff Rand
          jeff hammond
          You have no keep Extrude lines along a vector?
          i use TIG's version in the extrude edges suite.. i keep that entire toolbar turned on.
          dotdotdot
            mitcorb, the Tape Measure tool is the way to set a guidepoint or at least one way. After setting the guidepoint, select it and edges with vertices or ends and run the tool.
            TIG, thank you for this. I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
            • 2 / 2
