    Create a group and manipulate add geom
    11 Posts 3 Posters 1.2k Views 3 Watching
      Skippy1974
      Hello,
      I m a newbee
      couple of weeks, I start to dev using the ruby API
      For my plugin create a projector and all the parametric pyrammid
      I have 2 problems
      • I m not able to do the same think as File/import a skp file. I have to create a new one using the folloing
      Sketchup.open_file "C:/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F12.skp"
      proj = Sketchup.active_model.entities.add_group
      someone has a idea please?
      • after my creation, I want to put every body un a group and manupilate the group (translation / rotation / scale
        I m not able to add some thing or everything in a group
      create group
      group1 = ent.add_group projection_surface.all_connected (bad fonction)
      group1.name = "pyramid"
      idea
      thanks a lot
        model.definitions.load will let you import components.
        http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load
        I am not entirely sure what you are trying to do here...
        You want to import multiple components into group?
          Skippy1974
          thx
          I created several faces.
          I want ti select all and put in a group and after move the group
            All face geometry and intended group must be in the same context ['entities'].
            Make an array of the faces ['faces'].
            To make a group use...
            group=faces[0].parent.entities.add_group(faces)
            You can now change the group.name, group.layer, group.material etc.
            To move the group to a new point...
            pt=Geom::Point3d.new(1,2,3) ### or whatever x/y/z is required
            tr=Geom::Transformation.new(pt)
            then
            group.transform(tr)
            The 'group' is now at 'pt'...
              @skippy1974 said:
              thx
              If you are creating all the geometry your self, then create the group first, then add the geometry directly into the group. It a different approach than when you model where you create geometry and then group.
                Skippy1974
                Thx I will try tomorrow
                  Skippy1974
                  hello,
                  nothing works
                  I quite sure, the base of my code is ugly
                  could you help me to start with somthing well
                  # Name ;          Projector 0.9b
                  # Description ;   Generic projector drawing
                  # Author ;        Sebastien CANAUD
                  # Usage ;         1. Execute the script
                  #				  2. Fill in the GUI
                  # Type ;      	Script
                  # History;
                  #                 Beta  (25.August.2010) - beta version
                  # First we pull in the standard API hooks.
                  require 'sketchup'
                  # Show the Ruby Console at startup so we can
                  # see any programming errors we may make.
                  Sketchup.send_action "showRubyPanel;"
                  # Add a menu item to launch our plugin.
                  def create_generic_projector
                   	# Access the Entities object
                  	model = Sketchup.active_model
                  	ent = model.entities
                  	# Create the input box
                  	@projector_choise = "F22" if not @projector_choise
                  	projector_choise = ["F12","F22","F32", "LX1500", "CP635"]
                      enums = [projector_choise.join("|")]
                  	prompts = ["Projector", "Ratio H", "Ratio V", "lens", "Vertical Shift", "Horizontal Shift ", "Screen height","X", "Y","Z", "Heading", "Pitch", "Roll"]
                  	defaults = [@projector_choise,"4", "3", "1.03", "110", "0", "2.2", "0", "0", "0", "0", "0", "0"]
                  	results = inputbox prompts, defaults, enums,"Projector Settings"
                  	return if not results
                  	projector_choise, results[0],results[1], results[2], results[3], results[4], results[5], results[6], results[7], results[8], results[9], results[10], results[11] = results
                  	# load projector
                  	if( projector_choise == "F12" )
                  		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F12.skp"
                  	if( projector_choise == "F22" )
                  		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F22.skp"
                  	if( projector_choise == "F32" )
                  		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F32.skp"
                  	if( projector_choise == "LX1500" )
                  		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ChristieDigital_LX1500.skp"
                  	if( projector_choise == "CP635" )
                  		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/Hitachi_CP635.skp"
                  	# Projector settings
                  	ratioH = results[0].to_f
                  	ratioV = results[1].to_f
                  	lens = results[2].to_f
                  	verticalShift = results[3].to_f
                  	horizontalShift = results[4].to_f
                  	screenHeight = results[5].to_f
                  	x = results[9].to_f.mm
                  	y = results[10].to_f.mm
                  	z = results[11].to_f.mm
                  	heading = results[9].to_f.degrees
                  	pitch = results[10].to_f.degrees
                  	roll = results[11].to_f.degrees
                  	# temp
                  	norme = ratioH
                  	ratioH_in = ratioH.m
                  	ratioV_in = ratioV.m
                  	new_translationV_in = -verticalShift/2/100.0*ratioV/norme
                  	new_translationH_in = -horizontalShift/2/100.0
                  	scale_factor = screenHeight * (ratioH/ratioV)
                  	# Create the five points of the pyramid
                  	pt1 = [0, 0, 0]
                  	pt2 = [lens*ratioH_in/norme, -ratioH_in/2/norme, ratioV_in/2/norme]
                  	pt3 = [lens*ratioH_in/norme, ratioH_in/2/norme, ratioV_in/2/norme]
                  	pt4 = [lens*ratioH_in/norme, ratioH_in/2/norme, -ratioV_in/2/norme]
                  	pt5 = [lens*ratioH_in/norme, -ratioH_in/2/norme, -ratioV_in/2/norme]
                  	# Draw the faces
                  	ent.add_face(pt1, pt2, pt3)
                  	ent.add_face(pt1, pt3, pt4)
                  	ent.add_face(pt1, pt4, pt5)
                  	ent.add_face(pt1, pt5, pt2)
                  	projection_surface = ent.add_face(pt2, pt3, pt4, pt5)
                  	# translation for the horizontal and vertical shift
                  	tr = Geom;;Transformation.translation [0, new_translationH_in.m, new_translationV_in.m]
                  	ent.transform_entities tr, projection_surface
                  	# create group
                  	# scale
                  	s = Geom;;Transformation.scaling [0, 0, 0], scale_factor, scale_factor, scale_factor
                  	ent.transform_entities s, group1
                  	# rotation
                  	rh = Geom;;Transformation.rotation [0, 0, 0], [0, 0, 1], heading
                  	rp = Geom;;Transformation.rotation [0, 0, 0], [0, 1, 0], pitch
                  	rr = Geom;;Transformation.rotation [0, 0, 0], [1, 0, 0], roll
                  	ent.transform_entities rh, group1
                  	ent.transform_entities rp, group1
                  	ent.transform_entities rr, group1
                  # Create the message box
                  #UI.messagebox results[1], MB_MULTILINE, results[0]
                  #	printf("screenHeight ;%f",screenHeight)
                  if( not file_loaded?("projector.rb") )
                      add_separator_to_menu("Plugins")
                      UI.menu("Plugins").add_item("Generic Projector") { create_generic_projector }
                  file_loaded("projector.rb")
                    @skippy1974 said:
                    nothing works
                    Could you please be more specific? Error messages? Unexpected behaviour? (If so, what is expected?)
                      Skippy1974
                      hello,
                      As I m a bigginer, I played with the script but I m not sure the based works.
                      http://sebcanaud.free.fr/Perso/sketchup0.jpg
                      the goal is to import a .skp (it's a projector). as I m not able to load I open a new file with the good projector shape.
                              Sketchup.open_file "C;/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp"
                      After that, I create the pyramid of projection using specific parameter.
                      at the end I would like to move and rotate everthing. But I rotate only the pyramid I would like to merge the 2 group but as the Projector group is not loaded but as open file, I have not the hand on it
                          # create group
                          # scale
                          # rotation
                      http://sebcanaud.free.fr/Perso/sketchup1.jpg
                      thanks
                        You are opening the file because you could not load it as a component? Why did you not investigate to why you could not load the component?
                        hmm.... model.definitions.load did you perhaps assume would insert an instance of the component? model.definitions.load only loads the .skp into the model - you then have to place it in the model afterwards.
                        model = Sketchup.active_model projector_def = model.definitions.load "C:/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp" t = Geom::Transformation.new # This will load the component to the origin [0,0,0] projector = model.active_entities.add_instance( projector_def, t )
                          Skippy1974
                          Perfect
                          I made a stupid mistake
                          I investigate not
                          thanks a lot
