    Create a group and manipulate add geom
    11 Posts 3 Posters 1.2k Views 3 Watching
      model.definitions.load will let you import components.
      http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load
      @skippy1974 said:
      • after my creation, I want to put every body un a group and manupilate the group (translation / rotation / scale
        I m not able to add some thing or everything in a group
      I am not entirely sure what you are trying to do here...
      You want to import multiple components into group?
        Skippy1974
        thx
        I created several faces.
        I want ti select all and put in a group and after move the group
          All face geometry and intended group must be in the same context ['entities'].
          Make an array of the faces ['faces'].
          To make a group use...
          group=faces[0].parent.entities.add_group(faces)
          You can now change the group.name, group.layer, group.material etc.
          To move the group to a new point...
          pt=Geom::Point3d.new(1,2,3) ### or whatever x/y/z is required
          tr=Geom::Transformation.new(pt)
          then
          group.transform(tr)
          The 'group' is now at 'pt'...
            @skippy1974 said:
            thx
            If you are creating all the geometry your self, then create the group first, then add the geometry directly into the group. It a different approach than when you model where you create geometry and then group.
              Skippy1974
              Thx I will try tomorrow
                Skippy1974
                hello,
                nothing works
                I quite sure, the base of my code is ugly
                could you help me to start with somthing well
                # Name ;          Projector 0.9b
                # Description ;   Generic projector drawing
                # Author ;        Sebastien CANAUD
                # Usage ;         1. Execute the script
                #				  2. Fill in the GUI
                # Type ;      	Script
                # History;
                #                 Beta  (25.August.2010) - beta version
                # First we pull in the standard API hooks.
                require 'sketchup'
                # Show the Ruby Console at startup so we can
                # see any programming errors we may make.
                Sketchup.send_action "showRubyPanel;"
                # Add a menu item to launch our plugin.
                def create_generic_projector
                 	# Access the Entities object
                	model = Sketchup.active_model
                	ent = model.entities
                	# Create the input box
                	@projector_choise = "F22" if not @projector_choise
                	projector_choise = ["F12","F22","F32", "LX1500", "CP635"]
                    enums = [projector_choise.join("|")]
                	prompts = ["Projector", "Ratio H", "Ratio V", "lens", "Vertical Shift", "Horizontal Shift ", "Screen height","X", "Y","Z", "Heading", "Pitch", "Roll"]
                	defaults = [@projector_choise,"4", "3", "1.03", "110", "0", "2.2", "0", "0", "0", "0", "0", "0"]
                	results = inputbox prompts, defaults, enums,"Projector Settings"
                	return if not results
                	projector_choise, results[0],results[1], results[2], results[3], results[4], results[5], results[6], results[7], results[8], results[9], results[10], results[11] = results
                	# load projector
                	if( projector_choise == "F12" )
                		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F12.skp"
                		proj = Sketchup.active_model.entities.add_group
                	if( projector_choise == "F22" )
                		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F22.skp"
                	if( projector_choise == "F32" )
                		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F32.skp"
                	if( projector_choise == "LX1500" )
                		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ChristieDigital_LX1500.skp"
                	if( projector_choise == "CP635" )
                		Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/Hitachi_CP635.skp"
                	# Projector settings
                	ratioH = results[0].to_f
                	ratioV = results[1].to_f
                	lens = results[2].to_f
                	verticalShift = results[3].to_f
                	horizontalShift = results[4].to_f
                	screenHeight = results[5].to_f
                	x = results[9].to_f.mm
                	y = results[10].to_f.mm
                	z = results[11].to_f.mm
                	heading = results[9].to_f.degrees
                	pitch = results[10].to_f.degrees
                	roll = results[11].to_f.degrees
                	# temp
                	norme = ratioH
                	ratioH_in = ratioH.m
                	ratioV_in = ratioV.m
                	new_translationV_in = -verticalShift/2/100.0*ratioV/norme
                	new_translationH_in = -horizontalShift/2/100.0
                	scale_factor = screenHeight * (ratioH/ratioV)
                	# Create the five points of the pyramid
                	pt1 = [0, 0, 0]
                	pt2 = [lens*ratioH_in/norme, -ratioH_in/2/norme, ratioV_in/2/norme]
                	pt3 = [lens*ratioH_in/norme, ratioH_in/2/norme, ratioV_in/2/norme]
                	pt4 = [lens*ratioH_in/norme, ratioH_in/2/norme, -ratioV_in/2/norme]
                	pt5 = [lens*ratioH_in/norme, -ratioH_in/2/norme, -ratioV_in/2/norme]
                	# Draw the faces
                	ent.add_face(pt1, pt2, pt3)
                	ent.add_face(pt1, pt3, pt4)
                	ent.add_face(pt1, pt4, pt5)
                	ent.add_face(pt1, pt5, pt2)
                	projection_surface = ent.add_face(pt2, pt3, pt4, pt5)
                	# translation for the horizontal and vertical shift
                	tr = Geom;;Transformation.translation [0, new_translationH_in.m, new_translationV_in.m]
                	ent.transform_entities tr, projection_surface
                	# create group
                	group1 = ent.add_group projection_surface.all_connected
                	group1.name = "pyramid"
                	# scale
                	s = Geom;;Transformation.scaling [0, 0, 0], scale_factor, scale_factor, scale_factor
                	ent.transform_entities s, group1
                	# rotation
                	rh = Geom;;Transformation.rotation [0, 0, 0], [0, 0, 1], heading
                	rp = Geom;;Transformation.rotation [0, 0, 0], [0, 1, 0], pitch
                	rr = Geom;;Transformation.rotation [0, 0, 0], [1, 0, 0], roll
                	ent.transform_entities rh, group1
                	ent.transform_entities rp, group1
                	ent.transform_entities rr, group1
                # Create the message box
                #UI.messagebox results[1], MB_MULTILINE, results[0]
                #	printf("screenHeight ;%f",screenHeight)
                if( not file_loaded?("projector.rb") )
                    add_separator_to_menu("Plugins")
                    UI.menu("Plugins").add_item("Generic Projector") { create_generic_projector }
                file_loaded("projector.rb")
                  @skippy1974 said:
                  nothing works
                  Could you please be more specific? Error messages? Unexpected behaviour? (If so, what is expected?)
                    Skippy1974
                    hello,
                    As I m a bigginer, I played with the script but I m not sure the based works.
                    http://sebcanaud.free.fr/Perso/sketchup0.jpg
                    the goal is to import a .skp (it's a projector). as I m not able to load I open a new file with the good projector shape.
                            Sketchup.open_file "C;/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp"
                    After that, I create the pyramid of projection using specific parameter.
                    at the end I would like to move and rotate everthing. But I rotate only the pyramid I would like to merge the 2 group but as the Projector group is not loaded but as open file, I have not the hand on it
                        # create group
                        # scale
                        # rotation
                    http://sebcanaud.free.fr/Perso/sketchup1.jpg
                    thanks
                      You are opening the file because you could not load it as a component? Why did you not investigate to why you could not load the component?
                      hmm.... model.definitions.load did you perhaps assume would insert an instance of the component? model.definitions.load only loads the .skp into the model - you then have to place it in the model afterwards.
                      model = Sketchup.active_model projector_def = model.definitions.load "C:/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp" t = Geom::Transformation.new # This will load the component to the origin [0,0,0] projector = model.active_entities.add_instance( projector_def, t )
                        Skippy1974
                        Perfect
                        I made a stupid mistake
                        I investigate not
                        thanks a lot
