Create a group and manipulate add geom
Hello,
I m a newbee
couple of weeks, I start to dev using the ruby API
For my plugin create a projector and all the parametric pyrammid
I have 2 problems- I m not able to do the same think as File/import a skp file. I have to create a new one using the folloing
Sketchup.open_file "C:/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F12.skp"
proj = Sketchup.active_model.entities.add_group
someone has a idea please?
- after my creation, I want to put every body un a group and manupilate the group (translation / rotation / scale
I m not able to add some thing or everything in a group
create group
group1 = ent.add_group projection_surface.all_connected (bad fonction)
group1.name = "pyramid"
idea
thanks a lot
model.definitions.loadwill let you import components.
http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load@skippy1974 said:
I am not entirely sure what you are trying to do here...
You want to import multiple components into group? - after my creation, I want to put every body un a group and manupilate the group (translation / rotation / scale
thx
I created several faces.
I want ti select all and put in a group and after move the group -
All face geometry and intended group must be in the same context ['entities'].
Make an array of the faces ['faces'].
To make a group use...
group=faces[0].parent.entities.add_group(faces)
You can now change thegroup.name,group.layer,group.materialetc.
To move the group to a new point...
pt=Geom::Point3d.new(1,2,3)### or whatever x/y/z is required
tr=Geom::Transformation.new(pt)
then
group.transform(tr)
The 'group' is now at 'pt'... -
@skippy1974 said:
thx
I want ti select all and put in a group and after move the groupIf you are creating all the geometry your self, then create the group first, then add the geometry directly into the group. It a different approach than when you model where you create geometry and then group.
Thx I will try tomorrow
hello,
nothing works
I quite sure, the base of my code is ugly
could you help me to start with somthing well# Name ; Projector 0.9b # Description ; Generic projector drawing # Author ; Sebastien CANAUD # # Usage ; 1. Execute the script # 2. Fill in the GUI # Type ; Script # History; # Beta (25.August.2010) - beta version # First we pull in the standard API hooks. require 'sketchup' # Show the Ruby Console at startup so we can # see any programming errors we may make. Sketchup.send_action "showRubyPanel;" # Add a menu item to launch our plugin. def create_generic_projector # Access the Entities object model = Sketchup.active_model ent = model.entities # Create the input box @projector_choise = "F22" if not @projector_choise projector_choise = ["F12","F22","F32", "LX1500", "CP635"] enums = [projector_choise.join("|")] prompts = ["Projector", "Ratio H", "Ratio V", "lens", "Vertical Shift", "Horizontal Shift ", "Screen height","X", "Y","Z", "Heading", "Pitch", "Roll"] defaults = [@projector_choise,"4", "3", "1.03", "110", "0", "2.2", "0", "0", "0", "0", "0", "0"] results = inputbox prompts, defaults, enums,"Projector Settings" return if not results projector_choise, results[0],results[1], results[2], results[3], results[4], results[5], results[6], results[7], results[8], results[9], results[10], results[11] = results # load projector if( projector_choise == "F12" ) Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F12.skp" proj = Sketchup.active_model.entities.add_group end if( projector_choise == "F22" ) Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F22.skp" proj = Sketchup.active_model.entities.add_group end if( projector_choise == "F32" ) Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ProjectionDesign_F32.skp" proj = Sketchup.active_model.entities.add_group end if( projector_choise == "LX1500" ) Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/ChristieDigital_LX1500.skp" proj = Sketchup.active_model.entities.add_group end if( projector_choise == "CP635" ) Sketchup.open_file "C;/ANTYCIP/Sketchup components/Projectors/Hitachi_CP635.skp" proj = Sketchup.active_model.entities.add_group end # Projector settings ratioH = results[0].to_f ratioV = results[1].to_f lens = results[2].to_f verticalShift = results[3].to_f horizontalShift = results[4].to_f screenHeight = results[5].to_f x = results[9].to_f.mm y = results[10].to_f.mm z = results[11].to_f.mm heading = results[9].to_f.degrees pitch = results[10].to_f.degrees roll = results[11].to_f.degrees # temp norme = ratioH ratioH_in = ratioH.m ratioV_in = ratioV.m new_translationV_in = -verticalShift/2/100.0*ratioV/norme new_translationH_in = -horizontalShift/2/100.0 scale_factor = screenHeight * (ratioH/ratioV) # Create the five points of the pyramid pt1 = [0, 0, 0] pt2 = [lens*ratioH_in/norme, -ratioH_in/2/norme, ratioV_in/2/norme] pt3 = [lens*ratioH_in/norme, ratioH_in/2/norme, ratioV_in/2/norme] pt4 = [lens*ratioH_in/norme, ratioH_in/2/norme, -ratioV_in/2/norme] pt5 = [lens*ratioH_in/norme, -ratioH_in/2/norme, -ratioV_in/2/norme] # Draw the faces ent.add_face(pt1, pt2, pt3) ent.add_face(pt1, pt3, pt4) ent.add_face(pt1, pt4, pt5) ent.add_face(pt1, pt5, pt2) projection_surface = ent.add_face(pt2, pt3, pt4, pt5) # translation for the horizontal and vertical shift tr = Geom;;Transformation.translation [0, new_translationH_in.m, new_translationV_in.m] ent.transform_entities tr, projection_surface # create group group1 = ent.add_group projection_surface.all_connected group1.name = "pyramid" # scale s = Geom;;Transformation.scaling [0, 0, 0], scale_factor, scale_factor, scale_factor ent.transform_entities s, group1 # rotation rh = Geom;;Transformation.rotation [0, 0, 0], [0, 0, 1], heading rp = Geom;;Transformation.rotation [0, 0, 0], [0, 1, 0], pitch rr = Geom;;Transformation.rotation [0, 0, 0], [1, 0, 0], roll ent.transform_entities rh, group1 ent.transform_entities rp, group1 ent.transform_entities rr, group1 # Create the message box #UI.messagebox results[1], MB_MULTILINE, results[0] # printf("screenHeight ;%f",screenHeight) end #-------------------------------------------------------------------------- if( not file_loaded?("projector.rb") ) add_separator_to_menu("Plugins") UI.menu("Plugins").add_item("Generic Projector") { create_generic_projector } end #-------------------------------------------------------------------------- file_loaded("projector.rb") -
@skippy1974 said:
nothing works
Could you please be more specific? Error messages? Unexpected behaviour? (If so, what is expected?)
hello,
As I m a bigginer, I played with the script but I m not sure the based works.
the goal is to import a .skp (it's a projector). as I m not able to load I open a new file with the good projector shape.
Sketchup.open_file "C;/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp"After that, I create the pyramid of projection using specific parameter.
at the end I would like to move and rotate everthing. But I rotate only the pyramid I would like to merge the 2 group but as the Projector group is not loaded but as open file, I have not the hand on it# create group group1 = ent.add_group projection_surface.all_connected group1.name = "pyramid" # scale s = Geom;;Transformation.scaling [0, 0, 0], scale_factor, scale_factor, scale_factor ent.transform_entities s, group1 # rotation rh = Geom;;Transformation.rotation [0, 0, 0], [0, 0, 1], heading rp = Geom;;Transformation.rotation [0, 0, 0], [0, 1, 0], pitch rr = Geom;;Transformation.rotation [0, 0, 0], [1, 0, 0], roll ent.transform_entities rh, group1 ent.transform_entities rp, group1 ent.transform_entities rr, group1
thanks
You are opening the file because you could not load it as a component? Why did you not investigate to why you could not load the component?
hmm....model.definitions.loaddid you perhaps assume would insert an instance of the component?model.definitions.loadonly loads the .skp into the model - you then have to place it in the model afterwards.model = Sketchup.active_model projector_def = model.definitions.load "C:/Program Files/Google/Google SketchUp 7/Plugins/Projectors/ProjectionDesign_F12.skp" t = Geom::Transformation.new # This will load the component to the origin [0,0,0] projector = model.active_entities.add_instance( projector_def, t ) -
Perfect
I made a stupid mistake
I investigate not
thanks a lot
