    Help with branched followme plugin
    5 Posts 4 Posters 640 Views 4 Watching
    • liquid98L Offline
      liquid98
      Hi guys!
      I'm using sketchup now for almost 2 years, and can do a great lot
      of stuff with it. Sometimes when i need some info i look here at the forums.
      I'm also planning to start learnig ruby one of these days!
      But now I have a question for a script:
      I need to create a weird kind of rain-pipe out of a branched line:
      http://lh5.ggpht.com/_P7FrbhzJzPM/TJUlI6qMFXI/AAAAAAAAAoA/1kFIh1xXIPA/branche0.jpg
      Should become this:
      http://lh6.ggpht.com/_P7FrbhzJzPM/TJUlFU_vKvI/AAAAAAAAAn8/-oL0Tgp14EQ/branche1.jpg
      In this example I used components for the pipe bits and the plugin by TIG, free rotate. It was a lot of work. Is there any chance for a plugin witch automates this process?
      By the way: I have some global ideas for this script:
      Maybe with some help of you members I can write it myself. (I hope)
      Dank je wel (That's dutch for thanx)
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        You could use this http://forums.sketchucation.com/viewtopic.php?t=12354
        Or this http://forums.sketchucation.com/viewtopic.php?t=1709
          Or 'Extrude Edges By Face' http://forums.sketchucation.com/viewtopic.php?p=224218#p224218
          • liquid98L Offline
            liquid98
            Ok great feedback, thank you very much guys!
            • jeff hammondJ Offline
              jeff hammond
              i dunno, it seems easiest to me if you use chris fullmer's perpendicular face tools along with standard follow-me then solid union (or manually intersect/clean-up if you don't have SUpro)
              link to perp face tools
              [flash=660,405:3qptt0z2]http://www.youtube.com/v/Kq53IXsQ1aY?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:3qptt0z2]
              dotdotdot
