    Anyone have a copy of CrownMoldingGalore?
    6 Posts 3 Posters 670 Views 3 Watching
    • M
      mgfranz
      There use to be floating around a .skp called CrownMoldingGalore.skp which had about 50 different profiles of crown and cornice molding but I can't find it anymore. Anyone have a copy laying around?
      For some reason, the copy I have doesn't function anymore, I am unable to select faces. When I try to select a end face, the drawing acts like the face doesn't exist and will select the element behind the face. I don't know if this is a file issue or my copy of SU is flakey.
      "If you like what you do, it will never be work..."
      In memory of Sam Maloof, 1916-2009
        Is it these by RonS you're looking for?
        http://forums.sketchucation.com/viewtopic.php?f=40&t=3001&hilit=Profiles
        • M
          mgfranz
          No it's not, but those are even better than what I was looking for.
          Here is a screen shot of the file I was looking for and the original file that does not work right. In the third row down, and the 6th and 7th crown profiles in from the left, try to click on the face of the extruded end, see how you cannot select the profile? It's weird huh? I use to be able to select any profile and drag it into any other open .skp
          CrownMouldGalore.skp
          http://www.mgfic.com/pics/crownmouldgalore.jpg
          • D
            d12dozr
            Works fine for me, maybe you have a bad SU install?
            http://goo.gl/f7ooYh
            • M
              mgfranz
              d12dozr, thanks for the tip. That fixed it. Updated to 7.1.6860 and the issue went away. It's funny, since I installed MS SQL a week ago, a number of applications have started doing odd things, loosing registration codes, dropping function of certain features, etc.. Stupid Microsoft installers...
              • D
                d12dozr
                Glad you got it working πŸ‘
