    How to add entities to a nested group?
    32 Posts 4 Posters 2.4k Views 4 Watching
    • TIGT Online
      Aaargh... in your sample code you 'magick' a group out of 'thin air' [groupGroup] and then you add it into a group within a nested group. IF that does exists it certainly isn't inside the 'newRootGroup' [retitled 'rootGroup'] entities as you've just created that - so it will ultimately splat - you ARE cross-threading entities.
      Please try recasting your code [ignoring names and reusing references [variables] as it's getting confusing] in a way I outlined...
        draftomatic
        I think TIG gave up on me... 😳
          draftomatic
          @tig said:
          Aaargh...
          Argh indeed!
          Here it is - as simple as I can make it. This is 14 lines of code. Now tell me, what is wrong?
          The heirarchy is: model.entities -> group1 -> group2
          After the code finishes, it should be: model.entities -> group1 -> group2 -> faceGroup -> face+edges
          You can see that I'm creating these groups here, so there's no "magick!"
          ` # Testing group nesting
          model = Sketchup.active_model
          modelEntities = model.active_entities
          Create a face
          pts = []
          pts[0] = [0, 0, 0]
          pts[1] = [100, 0, 0]
          pts[2] = [100, 100, 0]
          pts[3] = [0, 100, 0]
          face = modelEntities.add_face(pts)
          Create root group
          group1 = modelEntities.add_group()
          Nest group2 inside group1
          group2 = group1.entities.add_group()
          Create group for faceGroup
          faceGroup = modelEntities.add_group(face)
          Nest in the first level
          newGroup1 = modelEntities.add_group(group1, faceGroup)
          group1.explode()
          Repeat to get it to the second level deep
          newGroup2 = newGroup1.entities.add_group(group2, faceGroup)
          group2.explode() # This crashes SketchUp`
          • Chris FullmerC Offline
            You are exploding group1 though. That does seem right to me. I can't look at it right now, but I probably can try later tonight.
            Seems like you should make a group and add the face data to it. Then make a group and add the facegroup to it. Then make a new group and add the other group to that. I'm sure that is exactly what you've already tried. I'll see if I can write up a fully working sample (unless someone else beats me to it).
            Chris
            All my Plugins I've written
              draftomatic
              Thank you very much Chris. And thanks to TIG too, even though I'm pretty sure he's moved on to bigger and better threads than this =D
                draftomatic
                Check it out. I have all these groups (group2 - groupN), under a root group (group1). And then I have faces, which I want to group with edges (faceGroup), and place in a nested group (group2 - groupN). There could potentially be many faceGroups, as shown in the picture...
                HOWEVER... my example script 2 posts up is a simplified version of this, with only one nested group (group2), which is initially empty.
                Clear enough? πŸ˜ƒ
                  I'm confused by all this...
                  Why are you not creating the entities directly into the appropriate group instead of trying to move them from group to group?
                    draftomatic
                    Because, my "real" code gets the faces by way of the user clicking a context menu on an existing face and clicking my plugin's option. So, the face is already there, but my example script is emulating this by creating a face inside of model.entities first...
                      ok...
                      What about:
                      1. user pick face
                      2. group the face ( group1)
                      3. get the definition of the group ( group1.entities.parent)
                      4. add a new instance of the group into the group you want it
                      5. erase group1
                      When you have the group instance you can use entities.add_instance to add a copy of the group.
                      It might avoid the problems if using .add_group with entities as argument and exploding.
                        draftomatic
                        @thomthom said:
                        ok...
                        What about:
                        1. user pick face
                        5. erase group1
                        Oh... tricky. I'll try that tomorrow.
                          # picked_face is the face the user selected
                          # group2 is the destination group
                          group1 = picked_face.parent.entities.add_group( picked_face.all_connected )
                          group_def = group1.entities.parent
                          group2.entities.add_instance( group_def, group2.transformation.inverse * group1.transformation )
                          group1.erase!
                            draftomatic
                            YAY! Thanks a ton thomthom, your solution works.
                            • 2 / 2
