    How to add entities to a nested group?
    32 Posts 4 Posters 3.1k Views 4 Watching
      This 'groupGroup' must be inside the same context as 'faceGroup'... OR...
      You already have
      rootGroup** IN model.entities
      AND
      face IN faceGroup IN newGroup [also named 'rootGroup'** BUT it is a different group] IN model.entities
      so simply use:
      groupGroup=newGroup.entities.add_group(faceGroup)
      groupGroup.name="groupGroup"
      face IN faceGroup IN groupGroup IN newGroup [named 'rootGroup'**] IN model.entities
      OR you add another a group to model.entities
      groupGroup=entities.add_group(newGroup)
      groupGroup.name="rootGroup" ###***
      face IN faceGroup IN newGroup [named 'rootGroup'] IN groupGroup [named yet another 'rootGroup'*] IN model.entities
      You just have to decide which groups contain which.
      Naming groups with the same name is plain confusing - why do it ?
      Give them each a unique reference and at the end name them appropriately...
        draftomatic
        Okay, you're just confusing me now, and what you're describing doesn't work for my situation. groupGroup already exists, and rootGroup already exists. I'm only creating them again in my example so that it can stand alone. So doing anything like groupGroup=newGroup.entities.add_group(faceGroup) isn't acceptable, because groupGroup is ALREADY THERE.
        Look TIG, can we get a bit simpler? Can you look quickly at test_group_bug.rb? I just simply don't understand why this line:
        LINE 49: newGroupGroup = rootGroup.entities().add_group(groupGroup, faceGroup)
        is breaking my code. As far as I can see, this is EXACTLY what you've told me to do. The contexts of groupGroup and faceGroup are identical (faceGroup.parent = rootGroup, and groupGroup.parent = rootGroup... I've checked).
        Moreover, the SAME CODE works several lines up, when I do the SAME THING, except in model.entities instead of in rootGroup. I'm very confused, and I need a straightforward answer. What EXACTLY is wrong about that line of code?
          The 'groupGroup' group DOESN'T really exist... except that you have made an empty group [too early] with that reference.
          Adding that empty group so early on into the mix and then trying to 'move' it into another group only confuses things.
          IF you already have a non-empty group with that reference then it's OK... but if not only make it when you need it otherwise.
          If you still can't get your head around this then please post a simple before and after set of uniquely named objects with their hierarchy - e.g.
          modelEntities=model.active_entities
          CONTAINING [at least] groupX [an existing group that isn't empty] and face [a face]
          OR ANY OTHER entities set with common objects you are to 'group' ?
          groupX > modelEntities
          face > modelEntities
          WHICH BECOMES faceGroup = modelEntities.add_group(face)
          face > faceGroup > modelEntities
          THEN group1 = modelEntities.add_group(faceGroup, groupX)
          face > faceGroup > group1 > modelEntities
          groupX > group1 > modelEntities
          THEN group2 = group1.entities.add_group(faceGroup, groupX)
          face > faceGroup > group2 > group1 > modelEntities
          groupX > group2 > group1 > modelEntities
          THEN group3 = group2.entities.add_group(groupX)
          face > faceGroup > group2 > group1 > modelEntities [STILL THE SAME AS BEFORE]
          groupX > group3 > group2 > group1 > modelEntities
          TO SEPARATE THE ENTITIES INTO SEPARATE GROUPS ETC ETC...
          YOU CAN GO ON AND ON...
          This has no 'names' just references to groups etc - you can add those later...
            draftomatic
            In my real code, there is already a CPoint inside "groupGroup." If you think it's a problem that groupGroup is empty, then fine, I just tried adding a CPoint to groupGroup in my example script. Still broken.
            Sir, my head is wrapped around this problem about 9 times already. I feel like you think I don't understand, but I do. I understand every word you have written, and I keep telling you, "I'm doing that, I'm doing that. Look at my code, look at my code."
            I did this already. Look at my script!!! Look at my screenshots!!! I am creating rootGroup and groupGroup. That is my hierarchy.
            I'm going to repeat my question again. What is wrong with line 49 of my previous example script? I COMPLETELY understand EVERYTHING you're telling me, and I believe I'm doing it, but it's still broken, and I don't see why!!!!!!!!!!
              Aaargh... in your sample code you 'magick' a group out of 'thin air' [groupGroup] and then you add it into a group within a nested group. IF that does exists it certainly isn't inside the 'newRootGroup' [retitled 'rootGroup'] entities as you've just created that - so it will ultimately splat - you ARE cross-threading entities.
              Please try recasting your code [ignoring names and reusing references [variables] as it's getting confusing] in a way I outlined...
                draftomatic
                I think TIG gave up on me... 😳
                  draftomatic
                  @tig said:
                  Aaargh...
                  Argh indeed!
                  Here it is - as simple as I can make it. This is 14 lines of code. Now tell me, what is wrong?
                  The heirarchy is: model.entities -> group1 -> group2
                  After the code finishes, it should be: model.entities -> group1 -> group2 -> faceGroup -> face+edges
                  You can see that I'm creating these groups here, so there's no "magick!"
                  ` # Testing group nesting
                  model = Sketchup.active_model
                  modelEntities = model.active_entities
                  Create a face
                  pts = []
                  pts[0] = [0, 0, 0]
                  pts[1] = [100, 0, 0]
                  pts[2] = [100, 100, 0]
                  pts[3] = [0, 100, 0]
                  face = modelEntities.add_face(pts)
                  Create root group
                  group1 = modelEntities.add_group()
                  Nest group2 inside group1
                  group2 = group1.entities.add_group()
                  Create group for faceGroup
                  Nest in the first level
                  newGroup1 = modelEntities.add_group(group1, faceGroup)
                  group1.explode()
                  Repeat to get it to the second level deep
                  newGroup2 = newGroup1.entities.add_group(group2, faceGroup)
                  group2.explode() # This crashes SketchUp`
                  • Chris FullmerC
                    You are exploding group1 though. That does seem right to me. I can't look at it right now, but I probably can try later tonight.
                    Seems like you should make a group and add the face data to it. Then make a group and add the facegroup to it. Then make a new group and add the other group to that. I'm sure that is exactly what you've already tried. I'll see if I can write up a fully working sample (unless someone else beats me to it).
                      draftomatic
                      Thank you very much Chris. And thanks to TIG too, even though I'm pretty sure he's moved on to bigger and better threads than this =D
                        draftomatic
                        Check it out. I have all these groups (group2 - groupN), under a root group (group1). And then I have faces, which I want to group with edges (faceGroup), and place in a nested group (group2 - groupN). There could potentially be many faceGroups, as shown in the picture...
                        HOWEVER... my example script 2 posts up is a simplified version of this, with only one nested group (group2), which is initially empty.
                        Clear enough? πŸ˜ƒ
                          I'm confused by all this...
                          Why are you not creating the entities directly into the appropriate group instead of trying to move them from group to group?
                            draftomatic
                            Because, my "real" code gets the faces by way of the user clicking a context menu on an existing face and clicking my plugin's option. So, the face is already there, but my example script is emulating this by creating a face inside of model.entities first...
                              ok...
                              What about:
                              1. user pick face
                              2. group the face ( group1)
                              3. get the definition of the group ( group1.entities.parent)
                              4. add a new instance of the group into the group you want it
                              5. erase group1
                              When you have the group instance you can use entities.add_instance to add a copy of the group.
                              It might avoid the problems if using .add_group with entities as argument and exploding.
                                draftomatic
                                @thomthom said:
                                ok...
                                What about:
                                1. user pick face
                                5. erase group1
                                Oh... tricky. I'll try that tomorrow.
                                  # picked_face is the face the user selected
                                  # group2 is the destination group
                                  group1 = picked_face.parent.entities.add_group( picked_face.all_connected )
                                  group_def = group1.entities.parent
                                  group2.entities.add_instance( group_def, group2.transformation.inverse * group1.transformation )
                                  group1.erase!
                                    draftomatic
                                    YAY! Thanks a ton thomthom, your solution works.
                                    • 2 / 2
