    Invoke draw(view) method on tool startup
    5 Posts 3 Posters 412 Views 3 Watching
    • T
      tomasz
      Is there a way to invoke the draw(view) method of a tool immediately on a tool startup?
      When I start my tool I want to draw some lines on the screen. Although the tool initializes correctly, the draw method is not started. I need to zoom in\out or minimize\maximize SU window to get the draw method fire up.
      What am I doing wrong or what I am not doing which I should?
      Tomasz
      • thomthomT
        It's and annoying limitation that activate doesn't have a view argument.
        What I end up doing is:
        def activate
          Sketchup.active_model.active_view.invalidate
        Some times, I've left it out, as my mouse move event continuously require the viewport to redraw.
        • TIGT
          As Thomthom said - at the start of the activate code invalidate the view - that's the same as zooming ?
          • thomthomT
            Changing the viewport cause it to invalidate and trigger the draw events.
            • T
              tomasz
              > def activate
              > end
              Thanks. It has done the trick.
              I've been trying
              def activate
                   draw(Sketchup.active_model.active_view)
              πŸ˜„ , but it has not worked.
