Invoke draw(view) method on tool startup
5 Posts 3 Posters 239 Views 3 Watching
    tomasz
    Is there a way to invoke the draw(view) method of a tool immediately on a tool startup?
    When I start my tool I want to draw some lines on the screen. Although the tool initializes correctly, the draw method is not started. I need to zoom in\out or minimize\maximize SU window to get the draw method fire up.
    What am I doing wrong or what I am not doing which I should?
    Tomasz
    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      It's and annoying limitation that activate doesn't have a view argument.
      What I end up doing is:
      def activate
        Sketchup.active_model.active_view.invalidate
      Some times, I've left it out, as my mouse move event continuously require the viewport to redraw.
        As Thomthom said - at the start of the activate code invalidate the view - that's the same as zooming ?
          Changing the viewport cause it to invalidate and trigger the draw events.
            tomasz
            > def activate
            > end
            Thanks. It has done the trick.
            I've been trying
            def activate
                 draw(Sketchup.active_model.active_view)
            😄 , but it has not worked.
