    [Plugin] DefaultScenes
    19 Posts 4 Posters 13.7k Views 4 Watching
    • P Offline
      Pout
      A very basic plugin that creates 7 default scenes (one for each standard Viewpoint)
      When executed again, the scene camera is updated to zoom the complete model (in case elements have been added)
      Accesable through the plugins menu.
      Update version 1.1:
      Top-bottom-left-right-back-front are in parallel projection
      ISO is perspective
      Version 1.1
      • CadFatherC Offline
        CadFather
        Thanks Pout - will give it a try 👍
          Bertier
          Poutastic !
          thank you Reinhart, great job.
            Bertier
            you are already a star : http://news.sketchucation.com/plugin-defaultscenes/
              Bertier
              could you add : zoom extent to each views ?
              please ?
              merci mon ami !
                Bertier
                ok, since I am asking for things, all views but "Iso" should turn camera into "Parallel Projection"
                ISo is a Perspective.
                  Bertier
                  seems like there is a bug hidding some of the drawing when changing views...
                  • P Offline
                    Pout
                    Hey Bertier,
                    I'll look into the questions! That is if i find some time...
                    Normally the zoom extents should already work. If you have added elements, run the plugin again and it must show all elements.
                    So in short:
                    • all except ISO in parallel projection
                    • can you send me a screenshot of the bug you are talking about?
                    • P Offline
                      Pout
                      Version updated to 1.1
                        Bertier
                        big up thank you
                          Bertier
                          works just fine !
                          excellent Pout
                            CadFather
                            really love this script - but it is not in the index..
                              Jim
                              Thanks, my regexp was missing a option. Should be updated soon.
                              • P Offline
                                Pout
                                If there are any additional suggestions, please let me know. 😄
                                Btw Jim, thx for adding me!
                                  CadFather
                                  yes, i was thinking of one... ..the views controlled by the axis - that way one could make default views in different orientations.
                                  • P Offline
                                    Pout
                                    Hey Cadfather,
                                    can you explain a bit more? Thx 😄
                                      CadFather
                                      yes, supposed you have a wall face at an angle, and you'd like the views to be referenced to that - if default scenes 'knows' the axis, then you can right-click on the wall face, 'align axis' and then run default scenes to get the orthographic views aligned to it.
                                      let me know if still unclear and i'll screen something up.. ..i get confused by myself.. 😛
                                      • P Offline
                                        Pout
                                        So you mean like this:
                                        When the axis have changed, ignore the default views of Sketchup and create the views based upon the new axis. So that the front is front for the new axis and not teh original SU one?
                                          CadFather
                                          Yes Pout.. that is it! 😎
