    [Plugin] DefaultScenes
    19 Posts 4 Posters 14.3k Views 4 Watching
    • B
      Bertier
      could you add : zoom extent to each views ?
      please ?
      merci mon ami !
      • B
        Bertier
        ok, since I am asking for things, all views but "Iso" should turn camera into "Parallel Projection"
        ISo is a Perspective.
        • B
          Bertier
          seems like there is a bug hidding some of the drawing when changing views...
          • P
            Pout
            Hey Bertier,
            I'll look into the questions! That is if i find some time...
            Normally the zoom extents should already work. If you have added elements, run the plugin again and it must show all elements.
            So in short:
            • all except ISO in parallel projection
            • can you send me a screenshot of the bug you are talking about?
            • P
              Pout
              Version updated to 1.1
              • B
                Bertier
                big up thank you
                • B
                  Bertier
                  works just fine !
                  excellent Pout
                  • CadFatherC
                    CadFather
                    really love this script - but it is not in the index..
                      Jim
                      Thanks, my regexp was missing a option. Should be updated soon.
                      • P
                        Pout
                        If there are any additional suggestions, please let me know. 😄
                        Btw Jim, thx for adding me!
                        • CadFatherC
                          CadFather
                          yes, i was thinking of one... ..the views controlled by the axis - that way one could make default views in different orientations.
                          • P
                            Pout
                            Hey Cadfather,
                            can you explain a bit more? Thx 😄
                            • CadFatherC
                              CadFather
                              yes, supposed you have a wall face at an angle, and you'd like the views to be referenced to that - if default scenes 'knows' the axis, then you can right-click on the wall face, 'align axis' and then run default scenes to get the orthographic views aligned to it.
                              let me know if still unclear and i'll screen something up.. ..i get confused by myself.. 😛
                              • P
                                Pout
                                So you mean like this:
                                When the axis have changed, ignore the default views of Sketchup and create the views based upon the new axis. So that the front is front for the new axis and not teh original SU one?
                                • CadFatherC
                                  CadFather
                                  Yes Pout.. that is it! 😎
