    [Plugin] DefaultScenes
    19 Posts 4 Posters 14.2k Views 4 Watching
      Bertier
      ok, since I am asking for things, all views but "Iso" should turn camera into "Parallel Projection"
      ISo is a Perspective.
        Bertier
        seems like there is a bug hidding some of the drawing when changing views...
          Pout
          Hey Bertier,
          I'll look into the questions! That is if i find some time...
          Normally the zoom extents should already work. If you have added elements, run the plugin again and it must show all elements.
          So in short:
          • all except ISO in parallel projection
          • can you send me a screenshot of the bug you are talking about?
            Pout
            Version updated to 1.1
              Bertier
              big up thank you
                Bertier
                works just fine !
                excellent Pout
                • CadFatherC Offline
                  CadFather
                  really love this script - but it is not in the index..
                    Jim
                    Thanks, my regexp was missing a option. Should be updated soon.
                      Pout
                      If there are any additional suggestions, please let me know. 😄
                      Btw Jim, thx for adding me!
                        CadFather
                        yes, i was thinking of one... ..the views controlled by the axis - that way one could make default views in different orientations.
                          Pout
                          Hey Cadfather,
                          can you explain a bit more? Thx 😄
                            CadFather
                            yes, supposed you have a wall face at an angle, and you'd like the views to be referenced to that - if default scenes 'knows' the axis, then you can right-click on the wall face, 'align axis' and then run default scenes to get the orthographic views aligned to it.
                            let me know if still unclear and i'll screen something up.. ..i get confused by myself.. 😛
                              Pout
                              So you mean like this:
                              When the axis have changed, ignore the default views of Sketchup and create the views based upon the new axis. So that the front is front for the new axis and not teh original SU one?
                                CadFather
                                Yes Pout.. that is it! 😎
