    Plugin Load Error!!
    25 Posts 6 Posters 10.0k Views 6 Watching
      smithryan07
      I have recently discovered that when I start SU I get a 'Load Error' dialogue box that says many of the newer plugins I've downloaded have not loaded. How do I fix this so they work?
      Thanks!!!
        Please take a 'screen-shot' of the 'error-message' and post here it so we might know what the problem is...
        Our psychic powers are not perfect... πŸ˜‰
          Also copy and paste the whole error message if you can.
            smithryan07
            'Error Loading File animation.rb
            undefined method GetString' for nil:NilClassError Loading File attributes.rb undefined method GetString' for nil:NilClassError Loading File box.rb
            undefined method GetString' for nil:NilClassError Loading File config.rb No such file to load -- TT_Lib/json.rbError Loading File config_ini.rb No such file to load -- TT_Lib/core.rbError Loading File FredoScale_Common.rb (eval):1: uninitialized constant FredoScale::T6Error Loading File inputbox.rb No such file to load -- TT_Lib/gui.rbError Loading File Lib6Config.rb uninitialized constant Traductor::T6Error Loading File Lib6Palette.rb uninitialized constant Traductor::T6Error Loading File Lib6Plugin.rb uninitialized constant Traductor::T6Error Loading File Lib6Protractor.rb uninitialized constant Traductor::T6Error Loading File Lib6Selmode.rb uninitialized constant Traductor::T6Error Loading File Lib6Startup.rb uninitialized constant Traductor::T6Error Loading File Lib6Tool.rb uninitialized constant Traductor::T6Error Loading File Lib6Web.rb uninitialized constant Traductor::T6Error Loading File LibOnSurface.rb uninitialized constant SUToolsOnSurface::TOS_DIRError Loading File LoaderOnSurface.rb No such file to load -- /LibTraductor_20.rbError Loading File ocean.rb undefined method GetString' for nil:NilClassError Loading File ShapeOnSurface.rb
            uninitialized constant SUToolsOnSurface::CODE_RectangleError Loading File tt_selection_toys.rb
            No such file to load -- TT_Lib/core.rbError Loading File ui_manager.rb
            No such file to load -- TT_Lib/core.rbError Loading File window.rb
            No such file to load -- TT_Lib/core.rb'
            Here is the entire load error. Should I still post a screenshot?
              How did you extract the files for the plugins?
              Can you provide a screenshot of your Plugins folder?
                There are clearly multiple problems...
                The first part says you are missing some files normally loaded by files in the ../Plugins/Examples/ ...
                Looks like ' sketchup.rb' isn't getting loaded from the ../Tools/ folder - is it there ???
                Fix those and we'll move onto the rest... πŸ€“
                  smithryan07
                  I extracted the files to my desktop and then moved them into my C Drive folder after they were extracted. I haven't had this problem until a couple of days ago.
                    smithryan07
                    It is not there. I dont know where it is?? ❓
                    • jeff hammondJ Offline
                      jeff hammond
                      sketchup.rb is in the tools folder.. not the plugins folder
                      [or should be there πŸ˜‰ ]
                      dotdotdot
                        I see a tt_selection_toys folder - that is not correct. Should be TT_Select_Toys
                        The footprint should be
                        http://forums.sketchucation.com/download/file.php?id=53762
                        <Sketchup>/Plugins/
                        TT_Select_Toys
                        Cursors
                        Icons
                        http://forums.sketchucation.com/download/file.php?id=53763
                        changelog.txt
                        ui_config.dat
                        ui_settings.dat
                        I'm guessing the other errors are also due to incorrect folder arrangement.
                          jeff hammond
                          yeah, for instance.. all those fredoscale files are supposed to be inside a folder called FREDOSCALE_Dir_20..
                          not sure what you have going with that folder "Curviloft 1.0c and LibFredo6 3.5c "
                          some of the TOS files are out of their folder as well.. (FreehandOnSurface.rb for instance should be inside the TOS folder..
                          that's after a quick glance and i'm sure there's plenty more..
                          it's looking like emptying the whole plugins folder and redownloading the plugins while following install instructions should do the trick πŸ˜‰
                          dotdotdot
                          • Dan RathbunD Offline
                            Dan Rathbun
                            @smithryan07 said:
                            I extracted the files to my desktop and then moved them into my C Drive folder after they were extracted. ...
                            You MUST extract them directly into the <Sketchup>/Plugins folder, while preserving the archived folders (allowing your zip manager to create subfolders in the Plugins folder for every folder embedded inside the zip archive.)
                            I'm not here much anymore.
                              smithryan07
                              Wow, thanks everyone. Looks like I have some work to do! Am I correct in assuming the best way to do this is to empty the folder and re-download the plugins like Jeff said?
                                Dan Rathbun
                                YES.. delete the whole folder.
                                YES.. redownload the zip files IF you erased them.
                                  Dan Rathbun
                                  Anyone (smart) will recommend installing ONE plugin at a time. Start Sketchup and make sure it works. Has it's menu items and/or toolbar(s).
                                  Then close Sketchup and repeat.
                                    smithryan07
                                    Thanks for everyones help, it is much appreciated. After a long grueling morning I was able to fix everything! 😎
                                    • SektaS Offline
                                      Sekta
                                      Hi all,
                                      Had a go at transferring my plugins over to SU8 and am having problems with profile Builder and Twilight. I was very careful to put everything in the exact spot where it was in SU7 plugins folder but obviously not careful enough. My transfer method was copy each and paste into SU8 plugins folder.
                                      Any help would be appreciated.
                                      Error Loading File 1001bit_loader.rb
                                      undefined method `+' for nil:NilClassError Loading File Lib6Config_31.rb
                                      uninitialized constant Traductor::T6Error Loading File Lib6Plugin_31.rb
                                      uninitialized constant Traductor::T6Error Loading File Lib6Startup_31.rb
                                      uninitialized constant Traductor::T6Error Loading File Lib6Tool_31.rb
                                      uninitialized constant Traductor::T6Error Loading File Lib6Web_31.rb
                                      uninitialized constant Traductor::T6Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/Twilight/init_twilight.rb
                                      no such file to load -- C:/Program Files/Google/Google SketchUp 8/Plugins/Twilight/TwilightLibError Loading File twilight.rb
                                        Sekta
                                        These error messages are quite helpful - they point you to 'missing files [inside missing folders]'... copy those over too and these errors should cease...
                                        For example...
                                        The 1001 error is probably missing stuff in its folder etc...
                                        You probbaly don't have the Fredo6 'Lib' folders copied etc etc...
                                        You also don't have the Twilight folder copied into the new v8 ../Plugins/ directory etc etc etc...
                                        You can't just move/copy the bare Ruby files... IF they have dependent files they are using in various sub-folders [very common in more complex tools] - so you need to move/copy those too [keeping the folder structure intact]............
                                        • SektaS Offline
                                          Sekta
                                          TIG,
                                          Thanks for the quick response, I will have a closer look this afternoon πŸ‘ πŸ‘
                                          • SektaS Offline
                                            Sekta
                                            Well,
                                            I have everything working except my most valued plugin....Profile Builder. I have messed it up somewhere, it doesn't[/img] work in SU7 now either. Below is a screen shot of the error I get. Any help to get PB up and running in SU8 would be appreciated. πŸ‘ πŸ‘
                                            screen shot
                                            • 1 / 2
