    [Plugin] TT_Lib²
    310 Posts 66 Posters 436.9k Views 66 Watching
      @bitslapped said:
      I do love this plugin and use it a lot in complex models.
      I assume you are referring to the CleanUp plugin? (This is the TT_Lib thread...)
      @bitslapped said:
      What I would love is for the 'smooth angle' feature to have an 'ignore materials' checkbox, so that coplanar faces of different materials do not merge.
      That would make it smooth the edge.
      @bitslapped said:
      E.g I have an organic surface with paths, lawn and garden beds on it. It would be great if the plugin smoothed the surface but left the edges between surface finishes.
      It's a good idea. I'll write it up for The List!
        bitslapped
        Sorry, yes I was talking about Cleanup3.
        Thanks for considering ThomThom, and yeah the 'ignore materials' was just using your existing terminology to add the feature.
        Ideally it would be something like a "maintain material edges" checkbox.
        Cheers mate, look forward to it 😄
          Roger
          ThomThom I am running 8 Pro and am trying to install "solid inspector." I have TT_Lib2 installed in the plugins folder and "tt_solid_inspector" installed in the "plug ins" folder.
          When I start 8 I can not find any indciation of the programs existence. Any ieas of where I can begin looking for the problem?
          Thanks.
          http://www.azcreative.com
          • K Offline
            kyyu
            Thanks.
            It saids the following, in the description. Did you check there?
            Access
            Tools > Solid Inspector
              Roger
              Thanks.
              Access
              I had to do a complete system restart before it appeared. Thanks Kwok
                LannorMov
                Gracias TT.
                Ya tenía caducada la versión anterior.
                  Version 2.5.5
                  Update for OSX users with Safari 5.0.6 or higher.
                  Not needed for Windows users.
                  Highly recommended for OSX users as Safari 5.0.6 will break some plugins with webdialogs.
                    driven
                    in 5.0.6
                    that seems to do the trick for cleanup [image with added css for scrollbar]
                    john
                      Cursed! I knew I'd forgotten something! x_X
                        Version 2.5.6
                        Update that hopefully fixes what appear to be a regression from 2.5.4 to 2.5.5 for some Windows users.
                          Version 2.5.7
                          Fixes the fix for the OSX fix that broke WebDialogs for some Windows users. 😒
                          ( I really hope everything is fixed now... 😕 )
                            Version 2.5.8
                            • Fixed some regression bugs in Inpubox
                            Recommended update!
                              driven
                              You'll be happy to know it works here...
                              I did tweek the height to 790 to stop the 'auto scrollbar' and added, ::-webkit-scrollbar to ui.css
                              cheers
                              john
                                Cheers. I've been too busy fixing the bugs to add this yet.
                                  angelorea_arq
                                  look
                                  http://img194.imageshack.us/img194/6426/errorzoom.jpg
                                  Uploaded with ImageShack.us
                                  • N Offline
                                    niks
                                    thank's so much for the update
                                      @angelorea_arq said:
                                      look
                                      What settings did you use for that?
                                      Also, could you post the reply in the CleanUp thread as the error is related to CleanUp and not TT_Lib?
                                        look
                                        Your profile says you use SU8, but exactly what version. The error was triggered in a part for SketchUp prior to SU8M1. Can you post your exact SketchUp version number in addition to the settings you used when you got the error?
                                          Version 2.6.0
                                          • LibFredo Update Checker support.
                                          • Lots of new features and fixes.
                                          Important!
                                          QuadFace Tools users need to update to this version!
                                            mamoune12345
                                            Hello
                                            Can you tell me please how can i install the TT lib on the sketchup ?
                                            Thank you and sorry for my english 😄
                                            • 15
                                            • 16
                                            • 3 / 16
