    [Request/Idea] On-Screen Keyboard Input
    16 Posts 7 Posters 3.3k Views 7 Watching
      This may have been mentioned before but I couldn't find any threads? I'm wondering if SU can display on-screen keyboard presses. For example, if demonstrating how to do a particular task your keyboard input would appear in the modeling area. I've seen in thom's Vertex Tool selection info displayed so can ctrl+c etc be displayed?
      Blender has a script which allows this and I see the value in such a tool.
      One more thing.... Can you print keyboard shortcuts or send them to excel?
        I would find that very useful, too.
        As to the keyboard shortcuts, there is a plugin. I'll see if I can find it although someone else will probably beat me to it.
        Edit to add: I found Shortcuts. It'll put the shortcuts into a window which can be copied and pasted into a document. http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=373
          Jim
          Windows has an on-screen keyboard, but at least in XP, it does not show the key being pressed.
          I haven't had a chance to use it much, but ShowOff looks good:
          http://www.donationcoder.com/Software/Skrommel/index.html#ShowOff
          The guy has a whole bunch of small utilities that you might also find useful.
          Martin wrote a plugin to show your shortcut keys:
          http://forums.sketchucation.com/viewtopic.php?t=23093
          I have one also which I can post in the plugins forum.
            Thanks for all the links guys, much appreciated... πŸ‘
            But Showoff isn't exactly what i need. Maybe this can explain better than my earlier ramblings...
            Click to enlarge....
              Rich, that's an interesting idea. I can see some good uses for that.
                Paste this into the Ruby Console
                puts Sketchup.get_shortcuts.sort
                to make a sorted list.
                To write the sorted list to a file you can change it to
                file=Sketchup.find_support_file('')+"/ShortCuts.txt";f=File.new(file,"w");f.puts(Sketchup.get_shortcuts.sort);f.close
                this makes a file called 'ShortCuts.txt' in the current 'Sketchup' program folder.
                  Thanks TIG πŸ‘
                  Is the OnScreen Rolling Reel possible?
                    Yes...
                    You'd make a piece of screen-text [say 6 lines long] in one corner, that has an observer and when you change your current tool it recalculates the text - avoiding duplicating the current one if you are doing lots of moves for example.
                    Adds a new top one and removes the last one in the list - it looks up the shortcut key for each tool listed [if any] and adds that to the tool's name as you suggest and adds it IF it has a shortcut...
                    πŸ€“
                    However, I can't see a big take up for this tool... so I won't be coding it any time soon... 😞
                      Thanks for explaining that it's possible. It's more than enough what you provided earlier for sending the shortcuts to .txt. Maybe someday I'll dive into ruby but as you mention not 'any time soon'.
                      • EarthMoverE Offline
                        EarthMover
                        Great idea for this. I think is would be useful if you could save them into a macro (action) command and rerun multiple commands in a single click to help speed up repetitive functions.
                        Content Creator at Skapeup
                          Awash with memories..... 😐
                            The impossible I can usually do straight away... BUT miracles take a little longer - there's a looooong queue for those πŸ˜’
                            • cottyC Offline
                              cotty
                              @tig said:
                              Yes...
                              πŸ€“
                              I think I have read about a plugin like this recently but I am not able to find it anymore (perhaps wrong search words...). Does anyone know this plugin? It will be helpful for video tutorials...
                              Thanks,
                              Cotty
                              my SketchUp gallery
                                Onscreen rolling Reel
                                Search the index for plugin by Rich O'Brien
                                • cottyC Offline
                                  cotty
                                  Thank you very much, I found it here. I searched osd, onscreen, ... but not "on screen" before πŸ˜’
                                  my SketchUp gallery
                                    driven
                                    .../Plugins/shortcuts.rb - makes and pops up a web page showing your keyboard shortcuts
                                    Appendix AR (All Ruby) in Edges to Rubies - the Complete SketchUp Tutorial
                                    Copyright 2010, Martin Rinehart
                                    Version 1.0, March 10-11, 2010
                                    this one work ok... john
