    I need another script
    5 Posts 3 Posters 832 Views 3 Watching
      Builder Boy
      Is there a plugin to do this, and all I have to do, is specify the length from the endpoint to the arc start point?
      All my plugins
        To what exactly πŸ˜•
        If you already have the 3D set of edges I suspect that you simply want to fillet the corners ❓
        There are several 'fillet' plugins available already...
        My '2D Tools' contains a '2D Fillet' tool, BUT it is one of the tools in the set that actually works in 3D too... πŸ˜„
        So to use that you'd simply activate the tool, enter the desired radius for the fillet [in the VCB] and pick the two edges forming the corner, repeat for each corner. There is no need to change the radius between fillets unless you want to do so... When you're done you'll have a guide-point at each arc's center, if/when you don't need these you can use 'Delete Guides' to clear them...
        In your illustrated example it'd need one type-in for the radius and eight clicks [at two per corner] to do [+ menu...delete guides] that's hardly hard work...
        πŸ€“
          Builder Boy
          πŸ€“
          Nice, but I would like to pre-select the geometry I want to fillet
          All my plugins
          • jeff hammondJ Offline
            jeff hammond
            if you want to pre-select a bunch of corners then enter a single fillet radius for all of them then go with the fillet tool found here: (the one called 2DFillet)
            Page not found – Villkor pΓ₯ casinon | Hitta ditt nya favoritcasino
            (www.ohyeahcad.com)
            if you want to do that and so much more (such as edit the fillet after the fact.. not to mention all the other possible conversions) then definitely pick up Fredo's latest update of BezierSpline (v 1.4):
            http://forums.sketchucation.com/viewtopic.php?t=13563
            here's a quick video showing first the ohyeahcad plugin then Fredo's..
            [flash=660,405:ooqspbvp]http://www.youtube.com/v/4KP-f2qVBoA?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:ooqspbvp]
            dotdotdot
              Builder Boy
              Thank you, Jeff Hammond! It's just what I was looking for!
              All my plugins
