    Component moving not precise
    22 Posts 9 Posters 2.4k Views 9 Watching
      davidwetzel80
      Hello everyone,
      First off I'm loving SketchUp and this forum. I was an avid AutoCAD user and made the switch about 4 weeks ago. Any way I'm building a geodesic dome and in the process I created 2 components. 1 pentagon and 1 hexagon. The edges are the same length. When I try to move them together from one vertex to another and then zoom in really tight they are not touching. From a distance they are and the snapping claims that is is too. However zooming in shows otherwise. When I explode both components and draw a line from the vertex it seems to be a true connection. I thought it had something to do with the unit precision but nothing worked. I'm also working with the free version, not pro. Maybe that has something to do with it?
      [b]If anyone can help It would be greatly appreciated.[/b]
      David
      • Wo3DanW Offline
        Wo3Dan
        Hi David,
        Could you attach the model here, with both pentagon and hexagon "snapped" together?
        Have you checked with dimensions or 'Tape Measurement' tool to see if they are realy the same size accross? In highest presicion?
        In "zoomed in" view, how much are vertices apart?
        • mitcorbM Offline
          mitcorb
          There may also be "extra vertices" in the construction very close together and you mean to hit one, but the other is selected. Or, maybe not. But I find myself zooming in sometimes almost to clipping to identify whether there are vertices very close. If so, use Ctrl+T to unselect everything, then Move, then mouse over the offending extra vert, and click drag it to the desired location. If it does not move, hit Alt to unlock the vert so that it can be dragged.
            davidwetzel80
            Hi Wo3Dan,
            I checked the edge sizes at the highest precision and the are the same. I also put them together again without selecting it first and the results were the same.
            I wanted to attach the model but I'm not sure how to post the file to this message. Can you tell me how?
              davidwetzel80
              I'm not finding any extra vertices in the pentagon or the Hexagon component. I also tried to move the component without selecting it first but I still have the same results. When I zoom in, it looks like its overlapping or not even touching it. This causes problems when I want to finish the dome model with the copy array tool.
              • jeff hammondJ Offline
                jeff hammond
                @honoluludesktop said:
                David, SU is a fairly easy 3d cad application to use for simple models, but there are tons of stuff that Acad can do that SU can not. Approach your tasks by integrating the best of both.
                wait, what? your advice is to use autocad if you want to move a component because sketchup can't do it? 😆
                when posting, look below the reply window and you'll see "Upload Attachment".. click that then click "choose file".. navigate to the file on your disk then either click 'add the file' or simply submit..
                .skp files can be uploaded directly to this forum so no need to zip them first.. (pretty sure there's a 4MB limit on the file size)
                dotdotdot
                • honoluludesktopH Offline
                  honoluludesktop
                  Jeff, Is that what I said????? Guess you must know me better then I do myself 🙂
                    mac1
                    Hello everyone,
                    David
                    not specific to your question but info maybe helpful http://groups.google.com/group/geodesichelp/topics http://sketchup.google.com/3dwarehouse/cldetails?mid=1f33552966b6f22224e5217d8a2e013a&num=50&scoring=m
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      See this SU file for ideas.
                      Hexagon and pentagon.skp
                        honoluludesktop
                        Addenda: I see you were responding to his technical question. Sorry, I was addressing his move from Acad to SU.
                          davidwetzel80
                          thank you! I guess I needed to look a bit harder. I'll upload the skp.
                            davidwetzel80
                            Here is the SKP. file. I also put the two components together. This is driving me crazy.
                            this is driving me nuts
                              davidwetzel80
                              @jean lemire said:
                              Hi folks.
                              H Jean,
                              Thanks for taking the time to solve my problem. I did your tutorial step by step. However I'm ending up with the same results. While I was in your tutorial I zoomed into your connected groups and they were fine! Everything was touching as I wanted. But when I try it on my machine it's a different story.
                              problem skp.skp
                                davidwetzel80
                                Thanks Jeff, I attached the file successfully.
                                  mac1
                                  Quick look
                                  Delete your pentagon and draw a new one at any radius then use the tape tool to measure one side then enter your 4' and re-scale it to that value. I could not confirm your measurement and all sides of the pentagon are not the same and trying to scale your original will not work
                                    mac1
                                    Quick look
                                    Update
                                    Explode the pentagon and then the curve and turn on end point in the styles menu and you will see multiple line segments at the corner which then gives different snap points. If you look carefully with the tape tool you will see the smae artifact. It does not show for the hexagon
                                      Jean Lemire
                                      Hi David, hi folks.
                                      See you file with some comments.
                                      problem skp.skp
                                        jeff hammond
                                        i saw that as well in the .skp (the extra endpoints) but i'm pretty sure that's nothing to do with what david is seeing..
                                        i made this video showing the concern.. if you have your camera set to parallel project or perspective with a very narrow FOV then you can zoom way in without clipping.. in this video, i'm zooming so far in that i can't even draw a line .000001" and have it fit in the su window..
                                        at that point, you'll see that the two components appear to not touch.. i then explode the two components and you'll see that they are in fact joined and coplanar..
                                        i dunno, i've never seen this behavior before but i assume it's something to do with the two objects being grouped and SU attempting to show the lines shared by both groups.. i'd like to recommend just not to worry about it and the joint is happening but i can understand david's concern and reluctance to accept that..
                                        [flash=660,405:37kbigqg]http://www.youtube.com/v/QVIGto2DhjI?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:37kbigqg]
                                        maybe someone can explain it a bit better than 'don't worry about it'
                                        dotdotdot
                                          mac1
                                          good pick up Jeff, I tried several things but still same result;
                                          Accel off
                                          Explode one ngon
                                          enabled snapping
                                          • Wo3DanW Offline
                                            Wo3Dan
                                            Hi David, at first I thought your problem was due to base endpoints in both groups being so close, in red direction. So moving the pentagon by grabbing its base endpoint could result in grabbing it by an inferencing point of the other group.
                                            At start endpoints differ 0.008346' in red direction. They still do after placing the pentagon "on" the top edge of the hexagon.
                                            Remedy would be to first move the pentagon more to the side and only then snap it to the hexagons enpoint. No exploding needed.
                                            Jean's remarks are a good catch too. Those extra enpoints may lead to problems at some point.
                                            But if it are realy talking about enpoints in different groups that aren't exactly overlapping..... well, Jeff is right. You are talking about macro level.
                                            See attached file I did some ime ago. In Scene2 try to connect a wireframe corner (top rectangle) to the top construction point with the line tool. All sides will jump to that point. Don't be bothered by this. I think you can still rely on SU's accuracy.
                                            SU_on_Macro_level.skp
                                            • 1 / 2
