    Component moving not precise
    22 Posts 9 Posters 2.7k Views 9 Watching
    • Wo3DanW
      Wo3Dan
      Hi David,
      Could you attach the model here, with both pentagon and hexagon "snapped" together?
      Have you checked with dimensions or 'Tape Measurement' tool to see if they are realy the same size accross? In highest presicion?
      In "zoomed in" view, how much are vertices apart?
      • mitcorbM
        mitcorb
        There may also be "extra vertices" in the construction very close together and you mean to hit one, but the other is selected. Or, maybe not. But I find myself zooming in sometimes almost to clipping to identify whether there are vertices very close. If so, use Ctrl+T to unselect everything, then Move, then mouse over the offending extra vert, and click drag it to the desired location. If it does not move, hit Alt to unlock the vert so that it can be dragged.
          davidwetzel80
          Hi Wo3Dan,
          I checked the edge sizes at the highest precision and the are the same. I also put them together again without selecting it first and the results were the same.
          I wanted to attach the model but I'm not sure how to post the file to this message. Can you tell me how?
            davidwetzel80
            I'm not finding any extra vertices in the pentagon or the Hexagon component. I also tried to move the component without selecting it first but I still have the same results. When I zoom in, it looks like its overlapping or not even touching it. This causes problems when I want to finish the dome model with the copy array tool.
            • jeff hammondJ
              @honoluludesktop said:
              David, SU is a fairly easy 3d cad application to use for simple models, but there are tons of stuff that Acad can do that SU can not. Approach your tasks by integrating the best of both.
              wait, what? your advice is to use autocad if you want to move a component because sketchup can't do it? 😆
              when posting, look below the reply window and you'll see "Upload Attachment".. click that then click "choose file".. navigate to the file on your disk then either click 'add the file' or simply submit..
              .skp files can be uploaded directly to this forum so no need to zip them first.. (pretty sure there's a 4MB limit on the file size)
              • honoluludesktopH
                honoluludesktop
                Jeff, Is that what I said????? Guess you must know me better then I do myself 🙂
                  mac1
                  Hello everyone,
                  First off I'm loving SketchUp and this forum. I was an avid AutoCAD user and made the switch about 4 weeks ago. Any way I'm building a geodesic dome and in the process I created 2 components. 1 pentagon and 1 hexagon. The edges are the same length. When I try to move them together from one vertex to another and then zoom in really tight they are not touching. From a distance they are and the snapping claims that is is too. However zooming in shows otherwise. When I explode both components and draw a line from the vertex it seems to be a true connection. I thought it had something to do with the unit precision but nothing worked. I'm also working with the free version, not pro. Maybe that has something to do with it?
                  [b]If anyone can help It would be greatly appreciated.[/b]
                  David
                  not specific to your question but info maybe helpful http://groups.google.com/group/geodesichelp/topics http://sketchup.google.com/3dwarehouse/cldetails?mid=1f33552966b6f22224e5217d8a2e013a&num=50&scoring=m
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas.
                    Hexagon and pentagon.skp
                    • honoluludesktopH
                      honoluludesktop
                      Addenda: I see you were responding to his technical question. Sorry, I was addressing his move from Acad to SU.
                        davidwetzel80
                        thank you! I guess I needed to look a bit harder. I'll upload the skp.
                          davidwetzel80
                          Here is the SKP. file. I also put the two components together. This is driving me crazy.
                          this is driving me nuts
                            davidwetzel80
                            @jean lemire said:
                            Hi folks.
                            H Jean,
                            Thanks for taking the time to solve my problem. I did your tutorial step by step. However I'm ending up with the same results. While I was in your tutorial I zoomed into your connected groups and they were fine! Everything was touching as I wanted. But when I try it on my machine it's a different story.
                            problem skp.skp
                              davidwetzel80
                              Thanks Jeff, I attached the file successfully.
                                mac1
                                Quick look
                                Delete your pentagon and draw a new one at any radius then use the tape tool to measure one side then enter your 4' and re-scale it to that value. I could not confirm your measurement and all sides of the pentagon are not the same and trying to scale your original will not work
                                  mac1
                                  Quick look
                                  Update
                                  Explode the pentagon and then the curve and turn on end point in the styles menu and you will see multiple line segments at the corner which then gives different snap points. If you look carefully with the tape tool you will see the smae artifact. It does not show for the hexagon
                                  • Jean LemireJ
                                    Jean Lemire
                                    Hi David, hi folks.
                                    See you file with some comments.
                                    problem skp.skp
                                    • jeff hammondJ
                                      i saw that as well in the .skp (the extra endpoints) but i'm pretty sure that's nothing to do with what david is seeing..
                                      i made this video showing the concern.. if you have your camera set to parallel project or perspective with a very narrow FOV then you can zoom way in without clipping.. in this video, i'm zooming so far in that i can't even draw a line .000001" and have it fit in the su window..
                                      at that point, you'll see that the two components appear to not touch.. i then explode the two components and you'll see that they are in fact joined and coplanar..
                                      i dunno, i've never seen this behavior before but i assume it's something to do with the two objects being grouped and SU attempting to show the lines shared by both groups.. i'd like to recommend just not to worry about it and the joint is happening but i can understand david's concern and reluctance to accept that..
                                      [flash=660,405:37kbigqg]http://www.youtube.com/v/QVIGto2DhjI?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:37kbigqg]
                                      maybe someone can explain it a bit better than 'don't worry about it'
                                        mac1
                                        good pick up Jeff, I tried several things but still same result;
                                        Accel off
                                        Explode one ngon
                                        enabled snapping
                                        • Wo3DanW
                                          Wo3Dan
                                          Hi David, at first I thought your problem was due to base endpoints in both groups being so close, in red direction. So moving the pentagon by grabbing its base endpoint could result in grabbing it by an inferencing point of the other group.
                                          At start endpoints differ 0.008346' in red direction. They still do after placing the pentagon "on" the top edge of the hexagon.
                                          Remedy would be to first move the pentagon more to the side and only then snap it to the hexagons enpoint. No exploding needed.
                                          Jean's remarks are a good catch too. Those extra enpoints may lead to problems at some point.
                                          But if it are realy talking about enpoints in different groups that aren't exactly overlapping..... well, Jeff is right. You are talking about macro level.
                                          See attached file I did some ime ago. In Scene2 try to connect a wireframe corner (top rectangle) to the top construction point with the line tool. All sides will jump to that point. Don't be bothered by this. I think you can still rely on SU's accuracy.
                                          SU_on_Macro_level.skp
                                          • TaffGochT
                                            TaffGoch
                                            Jeff is quite correct, in his assessment. You are seeing the effects of "super" micro zooming, where you are at your (and SketchUp's) limit of precision (0.000001)
                                            The points do, actually, share the same endpoint coordinates, but the display of the points don't correspond. This has to do with the order that SketchUp draws the entities. Since you have two groups/components, one gets drawn, then the other. If you had drawn a pentagon, then drawn the hexagon (with no grouping,) the entities would be "connected," and will be drawn, subseqently, adjacent line-after-line, employing the same screen/display location for the shared endpoints.
                                            To demonstrate that this is a display issue, only, you can explode the two, leaving only lines and faces. Do the extreme zoom, and you'll see what appears to be "healing" of the endpoints. Zoom back out, and make the existing (connected) entities into two groups (each face and it's bounding edges.) Extreme zoom-in, again, and you see the "errors" have reappeared.
                                            So, it's not an error in coordinates or precision, it's merely a display issue, when zoomed-in at the limits of precision. (You will note that, at extreme zoom-in, you often can not select any entities, either.)
                                            I can replicate very precise icosahedron/dodecahedron faces/edges, as components, and perform precise rotations, too. I just don't expect them to be accurate to more-than 6 decimals. That said, I've found precision to be excellent, and reproducible, from 1-to-6 decimals.
                                            Other users will confirm that SketchUp can exhibit odd behavior at extremely-small scales. I file this issue under the same category.
                                            -Taff
                                            "Information is not knowledge." -- Albert Einstein
