    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Render This - Marble
    32 Posts 19 Posters 6.6k Views 19 Watching
    • boofredlayB Offline
      boofredlay
      http://glasscollectiblesguide.com/wp-content/uploads/threemarbles.jpg
      Ok, I was sifting through old models and found a marble I tried rendering last year without success. So I put it up for a render challenge. Use this marble or make your own.
      The image above is not a rendering, just an example. My poor attempt is below.
      Marble.skp
      Here is my attempt.
      • olisheaO Offline
        olishea
        ooh nice challenge
        oli
          sepo
          I wish the model was smoother.
          • massimoM Offline
            massimo Moderator
            Here is my shot... 😄
              Something a little different [sic. shite]
              • EarthMoverE Offline
                EarthMover
                Render engine? Render Time? Technique & Approach? These should be mandatory with every render submitted in any "Render This" challenge. If not, then you might as well take "Ucation" out of SketchUcation. 🤓
                Content Creator at Skapeup
                  Good point Adam 👍
                  Render Engine - Simlab Composer
                  Render Time - 1hr
                  Technique/Approach - Basic Studio with Titanium texture. Studio HDR and a directional light. Glass was water ior value with plastic applied to interior feathers. Tried to create a more NPR feel to it. Not to everyones taste I'd imagine but I liked the result all the same.
                    andre51
                    This is a welcome break from the normal architectural stuff!
                    Used Maxwell - render time about 3hrs but image was OK after about 1hr.
                    Bump to surface a bit overdone.
                    • F Offline
                      fymoro
                      Here is my render,
                      Twilight 1.4, easy Hight+ preset, Hdri lighting, 8 minutes at 800/800.
                      PP with ACDsee pro for contrast and border...
                      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                      • F Offline
                        fymoro
                        Another image, preset easy 10, 40 minutes...
                        Twilight caustics... 😉
                        • olisheaO Offline
                          olishea
                          bravo guys!! 😮
                          oli
                            martin-art
                            Rendered in Shaderlight, taking 33 minutes at 800 x 600. Setup using a simple room environment with GI and bump.
                            http://i794.photobucket.com/albums/yy221/shaderlight/Shaderlight for SketchUp/marbles.jpg
                              boofredlay
                              Oh man, these are looking great. I must try again soon.
                              • BurkhardB Offline
                                Burkhard
                                ..another raw octane with hdri lighting.
                                [http://www.ia-plus.de(http://www.ia-plus.de)]
                                • massimoM Offline
                                  massimo Moderator
                                  Another one. Kerkythea again, unbiased 100 passes, procedural clipmap for the sack. No post pro with the exception of the vignette in Photoshop. 😄
                                  • stefanqS Offline
                                    stefanq
                                    V-Ray for SU, studio setup, 21 minutes, HDRI in background, and for illumination.
                                      EarthMover
                                      A quick stab at it. Vray/Max - 40 minutes at 1600x1200. Rendered with a studio setup and HDRI. Post process to color adjust, add the DOF and vignette. Also smoothed the geometry.
                                      Tweaked
                                      Raw Render
                                      • urgenU Offline
                                        urgen
                                        ...Hypershot 20 min+some photoshop...hot weather now ...
                                        --pupil forever...------
                                        • P Offline
                                          puck
                                          First crack at this one.
                                          Arion Render - 60 mins
                                          Set up time after sketchup was about 15 mins
                                          I've got another one cooking at the moment with a slightly different material for the outside of the marble. I'll upload it when it's done.
                                          Puck
                                          • P Offline
                                            puck
                                            Second one using Arion Render. This took about 1h 20m. I'm quite pleased with the results, would like to have put some DOF on it but I'm not sure how to do that with Arion yet.
                                            Puck
                                            • 1 / 2
