    Help shaping handle cut out
    7 Posts 4 Posters 546 Views 4 Watching
    • G Offline
      Gumleguf
      Hi there experts,
      I need your help teaching me how to cut out the following handle. I apologise for the drawing in advance, and hope your are still able to see what I mean:
      /Greg
        • Jean LemireJ Offline
          Jean Lemire
          Hi Greg, hi folks.
          See this SU file for ideas.
          Handle.skp
          • G Offline
            Gumleguf
            Guys! Thanks for your replies! I had not seen that you'd replied, since I received no notification emails from the forum. Hmm.... I'll make sure to check manually in the future.
            Thanks for your suggestions. I'll give a try once I get home, and get back to you.
            Cheers,
            Greg
            • G Offline
              Gumleguf
              TIG > I'm afraid I don't quite understand the steps involved in making your handle.
              Jean Lemire > Thanks so much for a brilliant description! Highly appreciated. I was able to build the following just from reading your instructions once:
              handle_01.skp
              Thanks again guys for helping out. 😍
              /G
                Draw the face representing the area to go.
                Draw the path it should follow.
                Select the path.
                Select the FollowMe tool.
                Pick the face and it sweeps along the path.
                The form is made, including unwanted geometry.
                Erase unwanted geometry - you now have the handle 'recess' removed from the slab, with its faces formed as needed.
                • jeff hammondJ Offline
                  jeff hammond
                  pretty much the same thing as jean's method but done on the wood(?) itself..
                  [flash=660,405:1g7vpdzm]http://www.youtube.com/v/cWlF6KgsUM8?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:1g7vpdzm]
                  dotdotdot
