    2 faces at the same place
    5 Posts 3 Posters 439 Views 3 Watching
    • Z
      Zacchia
      At the image you can see that sometimes objects have 2 faces at the same place and it should not be! It is not that easy to delete them. Is there a way or a plugin to do this automatic? If not this would be a nice idea for a plugin 😉
      • mitcorbM
        mitcorb
        I am not aware of a Delete Duplicate plugin. However, there may be one. I sure wish there was one. Have you checked Ruby Library Depot, Smustard, Jim Foltz's website, or the Plugin Index here in Sketchucation?
        Also, wait a while. Someone may answer who knows of this tool.
        • massimoM
          massimo Moderator
          Try with Thomthom's cleanup plugin. It has a "Removes duplicate faces" option.
          • Z
            Zacchia
            Yes that's it
            I had an earlier version from this plugin and i did not realised the update.
            Thanks a lot massimo and tomtom! And also mitcorb for answer.
            • mitcorbM
              mitcorb
              Aw,shucks. All I did was bump the thread 💚
