    Problems with a Model from the 3D Warehouse
    3 Posts 3 Posters 374 Views 3 Watching
      ricci1212
      Wanted to insert a Model from the 3D Warehouse.
      The Model is called:
      Kyocera KC130TM Photovoltaic Panel
      Unfortunately,it is not possible to fit/insert the panel on the roof.
      The roof panels should look like the attached file.
      Thanks for your help
      Ricci
      's Roof 180 suntech.skp
        Like a lot of 3Dwarehouse things it's not well thought out.
        It's made to be placed onto a flat surface, and it has a fixed slope.
        To get it to stick onto a sloping roof first insert it as a component into a model then edit the component and rotate its geometry to lay it flat on the ground, close the edit and edit the component's axes to somewhere logical [one corner?]. Now edit it in the 'Component Browser' so that it is set to 'stick' to sloping surfaces, Now place an instance of it onto a roof and it should stick onto any sloping surface as desired... πŸ€“
          mac1
          Several suggestions:
          1. Get the house model fixed before you do anything else. You should not have to draw the triangles to get the surfaces to form the way you have. Set the drawing axis to line up with the house edges to help you here;
          2. The roof surface measures 25367141.8 sq mm and the panels 1580x808 ( 1276.6 sq mm). That means if you have 100% packing efficiency you should be able to install 19 but the chimney prevents that so look at either optimization of the required number of panels based on you longitude where you are going to install and possibly reduce number required;
          3. Instead of installing all " vertically" the way you have try 90 deg rotation of some to see if you can get the 12 to fit ok
          4. Look at the combination of different panel sizes to get the wattage you need to fit your needs. If you check the panel supplier site I guess they would give you some options in this area.
            Good Luck
            BTW here is a small fix to your model http://sketchup.google.com/3dwarehouse/details?mid=c0eb29754d7d46969f30f02514717f00
