    Notched Box Plugin
    13 Posts 6 Posters 3.7k Views 6 Watching
    • C
      CNC Paul
      Hi All,
      I am try to find a plugin that creates a box where the edged are jointed by notches, any ideas
      Mant thanks
      Paul
      • M
        mac1
        @cnc paul said:
        Hi All,
        Mant thanks
        Paul
        Have not used this plugin but it maybe worth a look https://sites.google.com/site/wudworx/plugins-and-tools-2/wwxboardmaker
        • J
          Jim
          There is a slot and tab plugin also, which may be helpful.
          http://forums.sketchucation.com/viewtopic.php?t=28616
          Are you looking for a more specific solution to generate these boxes?
          • C
            cosycat
            Do you mean a dovetail joint ? if so, then this is a useful plugin
            http://www.finewoodworking.com/item/15393/dovetail-joints-in-sketchup-made-easy
            direct link
            http://thewoodenscrew.blogspot.com/
              After reading cosycat's reply, I am wondering if CNC Paul is referring to a box joined at the corners with box joints as shown on the left side of this box.
              http://woodgears.ca/dovetail/box.jpg
              If that is the case, the plugin cosycat mentioned would work. There's a better one albeit not free. See here. To make the box joint instead of a dovetail joint with either plugin, set the angle to 0.
              • C
                CNC Paul
                Hi Guys,
                Thanks for all your help, I think I need to explain a bit more...The plugin creates a 6 sided box with all edges notched as the picture, it also lays the panels out flat.
                http://i201.photobucket.com/albums/aa319/CNCPaul/Snap_20100817065630_001.jpg
                Paul
                  They're just wide box joints. The dovetail plugins mentioned would certainly do those notches. As to laying the pieces out flat, I'm not familiar with one that would that part. I assume your next step after alying them out flat is creating the tool paths to make the parts?
                  • C
                    CNC Paul
                    Yes
                    sorry for the long winded reply
                      Paul, no one could accuse you of being long-winded.
                      So if you are able to speed up drawing the tabs or box joints, would manually laying the parts out flat be a problem?
                      • K
                        kyyu
                        Not a plugin, but there is a free software that does generate and lays out the parts for the box. The output is pdf. I did convert their sample pdf to dxf a while back. And imported it into sketchup. One thing to note is that, it's not layed out like you would expect, so hard to figure out when trying to actually assemble the box.
                        http://rahulbotics.com/personal-projects/boxmaker/?boxmaker/
                        • J
                          Jim
                          Thanks kyuu, that's a nice little program.
                          • C
                            CNC Paul
                            Kyyu,
                            Many thanks for the link, that is perfect.
                            • C
                              CNC Paul
                              LOL,
                              No, not really, I just thought it would quicker to output the parts, nest them and the cut the parts.
