    Notched Box Plugin
    13 Posts 6 Posters 3.7k Views 6 Watching
    • C
      cosycat
      Do you mean a dovetail joint ? if so, then this is a useful plugin
      http://www.finewoodworking.com/item/15393/dovetail-joints-in-sketchup-made-easy
      direct link
      http://thewoodenscrew.blogspot.com/
        After reading cosycat's reply, I am wondering if CNC Paul is referring to a box joined at the corners with box joints as shown on the left side of this box.
        http://woodgears.ca/dovetail/box.jpg
        If that is the case, the plugin cosycat mentioned would work. There's a better one albeit not free. See here. To make the box joint instead of a dovetail joint with either plugin, set the angle to 0.
        • C
          CNC Paul
          Hi Guys,
          Thanks for all your help, I think I need to explain a bit more...The plugin creates a 6 sided box with all edges notched as the picture, it also lays the panels out flat.
          http://i201.photobucket.com/albums/aa319/CNCPaul/Snap_20100817065630_001.jpg
          Paul
            They're just wide box joints. The dovetail plugins mentioned would certainly do those notches. As to laying the pieces out flat, I'm not familiar with one that would that part. I assume your next step after alying them out flat is creating the tool paths to make the parts?
            • C
              CNC Paul
              Yes
              sorry for the long winded reply
                Paul, no one could accuse you of being long-winded.
                So if you are able to speed up drawing the tabs or box joints, would manually laying the parts out flat be a problem?
                • K
                  kyyu
                  Not a plugin, but there is a free software that does generate and lays out the parts for the box. The output is pdf. I did convert their sample pdf to dxf a while back. And imported it into sketchup. One thing to note is that, it's not layed out like you would expect, so hard to figure out when trying to actually assemble the box.
                  Site not found · DreamHost
                  The owner of this domain has not yet uploaded their website.
                  (rahulbotics.com)
                    Jim
                    Thanks kyuu, that's a nice little program.
                    • C
                      CNC Paul
                      Kyyu,
                      Many thanks for the link, that is perfect.
                      • C
                        CNC Paul
                        LOL,
                        No, not really, I just thought it would quicker to output the parts, nest them and the cut the parts.
