    Tools on surface-24 segment circle
    4 Posts 4 Posters 897 Views 4 Watching
      sketchup73
      Hi hot blooded sketchuppers. 💚
      i have just been using the plugin ' tools on surface'
      the circle on surface comes with a default of 24 segments.
      is there way to raise these 24 segments to higher number. ❓
      • BoxB Offline
        Create your circle then type 50s and enter, or whatever number you want, S stands for sides [segments].
        • mitcorbM Offline
          mitcorb
          If there is no preset(I didn't check), you certainly can re-segment by Window>EntityInfo>edit the segment field.
          If I get a chance to check it I will edit this reply, unless someone else responds faster.
          Best wishes.
          Edit before final submit: See what I mean?
          • massimoM Offline
            massimo Moderator
            Hi sketchup73, you can change the preset number of segments (and many other presets) by going to tools-->Fredo6 collection-->Tools on surface-->default parameters.
            Then you need to restart Sketchup in order to make that change effective. 😉
